Results 1 to 17 of 17
    Dec 2016
    NY
    Default 2016 F3 Limited battery tender hook up HELP
    Hey Gang.
    Looking to put away the bike for the winter, planning to use a battery tender. Is there any way to hook up the tender without having to get to the battery terminals? Thought I read there were leads somewhere on the bike to eliminate the need to expose the battery terminals? Or am I dreaming? LOL.
    Nov 2013
    Oro Valley Arizona
    Best to hook the pig tail to the Battery terminals and leave them permanently attached. Find a good place to route them. Next time just plug and unplug. Easy Peasy.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    As mentioned: get a "Ring Terminal Assembly". Hook up directly to battery and you're good to go. I prefer the ones with a inline fuse. When not using for charging/maintaining the battery, you can use to run accessories if needed.
    Joe
    2023 F3
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    Quote Originally Posted by tibadoe View Post
    I never thought about using that connector to temporary connect accessories! Hmmm...
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    That is the exact same set up I use. I have every vehicle I use set up the same way including my Spider,quads, snowmobiles, car, truck and R.V.
    batterys. I have no less than 11 maintainers going at one time and have my snowmobile etc,batterys last up to 13 years. I have 6 of those cheap
    Harbour Freight maintainers that have been plugged in 24/7 for 10 years and have never had one fail and have worked great.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    Dec 2016
    NY
    Just went to wire a pigtail to the battery and realized one has already been wired ! Very cool, thank you all for your responses.
    Active Member Navvet's Avatar
    Apr 2016
    NC
    Quote Originally Posted by Mjrcpd View Post
    Hey Gang.
    I mount these to all my equipment with batteries, Makes it easier having a standard connection for everything.
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
    Active Member Bruiser37's Avatar
    Tucson Arizona
    Default Battery tender charger cable
    Hey Gang.
    No way, you have to get to battery terminals to install cable. Never tried it but they make adapter bat cable that plugs into a cigaret lighter... beware of complications that could result. Access to bat terminals only safe way to go especially for length of time spyder is winterized. This is a no brainer.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Mar 2017
    Yup, the f3 commes with one n place. I did put a larger fuse in it
    Mar 2017
    Forgot to mention that I put a direct to battery coax outlet where the heated grip passenger grip knob goes in the left saddlebag area.
    Click pic for details.
    Apr 2017
    North Central Florida
    Quote Originally Posted by Bruiser37 View Post
    Absolutely not true.
    Some (many?) models have a power socket (cigarette lighter style) that is hot all the time......or can be made hot all the time by moving a fuse.
    Also, some battery tenders come WITH a plug specifically intended to be used that way.
    Unless you install something yourself and screw it up, I don't see what the potential "complications" are.
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Quote Originally Posted by Rattlebars View Post
    I was unaware if this. where is it. I installed a pigtail to my battery and I must have missed it. I do not recall seeing anything ran to my battery would it be wired elsewhere? just curious!
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Jul 2011
    Silver Spring, MD
    2016 F3T SM6 , Silver
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Spyder601 View Post
    Some dealers pre-install the battery tender leads (like Imotorsports) but they do not come pre-installed from the factory.
    Mar 2017
    Quote Originally Posted by stebrock View Post
    Yes, mine was installed. I have experience with exactly ONE Spyder... my F3-T. It was installed in the Frunk. I use the circuit for many things.
    >CLICK ME<
    Mar 2016
    Olathe, KS
    like Stebrock said, some dealers installed them as I just found out. I have a 2017 F3 Limited that we bought new and I just looked this post up and started to follow Spyderdips post, had my Battery Tender leads ready, took out the trunk liner and was about to unhook the battery cables when I realized that mine already had the Tender leads installed exactly like is in Spyderdips post. I didn't realize that my dealer, Jay Hatfield Powersports in Frontenac, Kansas had installed it. They never said anything about it. I could of had it plugged in all this time.
    Spyderdips - great post on the install.
    Mar 2017
