I'm using your post as a quote, because you brought up the possibility of a tire size conflicting / upsetting the NANNY...….Because the Spyder suspension design restricts what tire sizes can be used, the difference between the front and rear tires ( even at extreme differences ) isn't large enough to Upset the Nanny. This is assuming you are using Stock BRP wheels or aftermarket that match the BRP sizes ……. Mike
Yes Mike you are correct. Since purchasing those tires & some more research, I've fitted 215/55 along with the 175/55 [ Bridgestone potenza ] on my RT & no problems. The 225/55 would have been ok also but for clearance issues. Thanks mate.
“The 225/55 would have been ok also but for clearance issues” ......eh? ......doesn’t that mean it would NOT have been OK, Trev?
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Pete, I have built myself a '' inner guard '' ie a rock guard which is attached via 2 u-bolts DSCN1596.jpgto the rear shock mounting cross brace. Without the guard, I'am pretty sure you could squeeze in the 225/55 DSCN1598.jpg
I have built myself a '' inner guard '' ie a rock guard which is attached via 2 u-bolts to the rear shock mounting cross brace. Without the guard, I'am pretty sure you could squeeze the in 225/55
Ahhhhhhhh. Gotcha Trev......makes sense.......I bought a rock guard and it protruded a little into that space which is why I went for the 205 Kuhmo, just in case.
HeliBars Handlebars
Kenda Kanine rear.
