Results 1 to 14 of 14
    Nov 2015
    Mickleton,nj
    Default 2018 F3 Limited - How do I turn off the radio
    Hello,
    Love the new F3 but have a question. Is there a way to turn off the radio or do we just have to leave the volume very low/muted so we don’t hear it? We ride with music streamed from our phone to our Scala Packtalks so we don’t need the F3 radio on.
    Thanks in advance
    Steve
    Volume set to the lowest is as close as you are going to get with turning the radio "off."
    But...you would think they could supply an "off" switch for the money.
    Nov 2015
    Mickleton,nj
    Thanks, it’s the same on my Harley, no off just volume muted.
    Steve
    Bossier LoUiSiAna
    Mute or AUX mode with nothing connected
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Mar 2017
    You could set the input to AUX (short press the ECO button then press the MODE button opposite the ECO) and make sure nothing is plugged into the AUX input = silence. Or, set it to NAV same result. If you have a zumo with audio out, NAV would be your best bet. That way you would hear the GPS prompts and have silence when not.
    I could not afford the pricey zumo so I modified a Garmin nüvi 56 to have audio out. Details can be found CLICK-->here< along with how to locate the audio in for NAV and lots more info.
    May 2018
    Morriston, florida
    Default Turn radio off
    Yes, seems to work most of the time now with the new sw. Version.
    Turn vol all the way down the hold the down joy button. It will turn off.
    The X will appear showing it is off. However, it seems to come on whenever it wants too. Untill last update now seems to stay off most of the time. I think they still have some sw fixes to do yet.
    Nov 2015
    Mickleton,nj
    Thanks for all the suggestions, I’ll try the lower volume first to see how that works.
    Steve
    Mar 2017
    Quote Originally Posted by AsphaltEagle View Post
    How does one obtain a sw update?? TIA
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Rattlebars View Post
    I have the same question. Trading my 2016 F3 L for a 2018 F3 L tomorrow.
    Thanks, Rick
    Sep 2009
    La Valle, WI
    Quote Originally Posted by stebrock View Post
    Thanks, Rick
    Your dealer should have all software up to date when you pick it up. The latest radio update is 13.20 unless there has been another since June 2018. Haven't read about any. 13.20 fixed most problems. When you pick it up go into settings. Then scroll down to about. You can see the latest update there.
    2018 F3 Limited , Oxford Blue
    Nov 2008
    Canada, Ontario
    Default I had the same issue
    and a software update when I had my service done in September fixed it. Now it is muted with an X on the speaker icon. It was clearly a bug.
    2018 F3 Limited black, dark
    Mar 2013
    Quote Originally Posted by JP58 View Post
    Do not assume this as I did only to find out otherwise. When salesman was showing us the controls and how the fault codes can be displayed there was one showing so he took it to service to have it cleared.
    When he came back he told us it would be awhile as there were a number of sw updates that were being downloaded.
    Bottom line - ask to be sure.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2017
    2016 F3T. I have no ABOUT selection in settings.
    Sep 2009
    La Valle, WI
    That's because you have a 2016 with old screen. 2018 has the new screen.They can be updated with new software.
