Results 1 to 4 of 4
Thread: 2015 SST 998
    Apr 2017
    Pittsville Maryland
    Default 2015 SST 998
    I found riding in the tow mode (not towing) enables quicker downshifts - I dont have to manually downshift as much-any ones opionions / thoughts on this.
    Steve
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Sounds right. What exact thought or opinion are you wanting?
    If you're asking whether or not you can just ride around in tow mode all of the time. Sure why not? It might drop your gas mileage slightly, but if it gives the machine a response that more closely matches your needs/desires, then by all means keep it in that mode. I can see no harm done mechanically.
    2020 RTL SE6
    Mar 2013
    Oz
    Agree
    My ST was in tow mode all the time, no harm done. I always thought it let the revs get way too low before downshifting when not in tow mode. Generally I do my own downshifts but often-times I wanted to change right where tow mode wanted to change, so I let it do its own thing more often.
    Bossier LoUiSiAna
    SE5? If so the "Trailer" mode changes the parameters of shift patterns, if you watch the RPM's closely that is. & will affect your gas mileage but nothing severe, especially without actually towing anything. Supposedly affects braking too, might just be in combination with the passenger pillion switch strap a sandbag or something on there to test if you like.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
