Results 1 to 13 of 13
    Jun 2014
    ny
    Default pulling a tow behind trailer
    when towing my trailer i was wondering what the best cruising speed i should use when i 4th gear & 5th gear. my
    trailer with load is around 400lbs.
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    The speed isn't really an issue unless you get busted for speeding. Keep in mind that you need a fair bit more stopping room and on downhill turns it will push a bit.
    Mar 2015
    Brockport, NY
    Default Rpm seems to be the guahe
    I tend to see best fuel mileage around the 3000 rpm range. Not always an option, but when we can I keep it around there.
    2014 RT-S Pearl White
    Nov 2015
    Chardon, OH
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Is that a 2013? Which transmission?
    Doug
    ”Freedom is not a loophole”
    Jun 2014
    ny
    yes i have a 2013 rt-s so the 3k rpm is not right for me
    Dec 2015
    Oakley Utah
    What other kind of trailer is there, besides a pull-behind? A push in front of?
    2014 RTL Platinum
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    I am so much happier pulling my Time out Trailer with my Gold Wing than with my 2014 RS-M. Starting from a complete stop is so much easier, no slipping the clutch to get going and as long as I stay around 60mph my gas milage stays @ ~ 36 mpg. Looking forward to extensive traveling in 2019 when retired.
    Al in Kazoo
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Dec 2015
    Oakley Utah
    when towing my trailer i was wondering what the best cruising speed i should use when i 4th gear & 5th gear. my trailer with load is around 400lbs.
    In NYC ? Are you yanking our chain?
    2014 RTL Platinum
    Jun 2014
    ny
    a trailer that you load the bike into
    Jun 2014
    ny
    i use my trailer on sunday mornings when heading out to the island. no way in hell could i go to manhattan with it.
    at 5:30am i cruise.
    Idaho
    With the 2013 RT I had maintaining speed was the controlling factor. I rode many miles in 4th at 70 mph because of wind & up hills and it wouldn't hold speed in 5th. My trailer was in the 400+ lbs range. I pretty much always dropped it into 4th while passing semis. I usually set my cruising speed by the signs along the side of the road! From speed limit to +5.
    2014 Copper RTS
    Jun 2014
    ny
    thanks, that pretty much tells me what i wanted to know & THIS IS WHAT THE FORUM IS FOR.
    Idaho
    My comment does disregard the impact on mpg. The heavier the trailer, the greater it's side to the wind, the faster you cruise, the lower the elevation where you're riding, the lower your mpg. My best mpg ever was w/ no trailer going over the Rockies!
    2014 Copper RTS
