Results 1 to 11 of 11
Thread: Flat Tire
    Jul 2011
    Mitchell, Ontario, Canada
    Default Flat Tire
    Interesting video from Pierre getting a flat tire.
    https://youtu.be/_RyLza9TfVU
    2018 F3 LIMITED
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    Thanks for the post, Billy. Interesting situation, and one that I hope I’ll never encounter.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Jun 2016
    Harrington, Australia
    Bugger....I just get an “error while loading” message.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2014
    Mint Hill, NC
    Pete
    Me too. Did a search, found video, got error message.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default Thanks .....
    Too bad he did not do the repair on the side of the road and show all how that is done...Glad I'd went as well as it did.....
    ​2012 RS sm5
    Aug 2008
    MA & NH
    Played for me.
    Jul 2014
    Mint Hill, NC
    Temporary error message; played fine next morning.
    Cognac 2014 RT-S
    Jun 2014
    ny
    Just curious, did you use a combi patch or just a radial patch on it?
    May 2013
    Indiana
    Default RUNFLAT Tires
    Just curious, are their runflat tires available for the Spyder sized tires??????
    Mike
    2021 Marsala Red Metallic RT Limited
    Nov 2012
    Pueblo Colorado
    Default Hit a rock and blew right front tire- still stable like Pierre said
    Like Pierre said, losing air wasnt the worst although it did pull to the right. Last Monday on our way to Tucson we got caught in a heavy downpour and I hit a rock washed down on the road and blew the sidewall on the right Kumho . I couldn't get a Kumho at the Show Low AZ Discount tire shop (nearest supply was either Nevada or Dallas TX). I do feel that the heavier sidewal and carcass of the Kumho prevented damage to the wheel and allowed me to roll about two miles to a wide spot where I could pull over safely.
    Had to wait 3 hrs for a flat bed tow with alternating rain with some hail, but it could have been worse.
    The Discount tire shop had a set of Nankang AS-1 tires in the same 155/60R15 size at $61 a piece so I now have run them about 1000 miles with good roll and balance, but am not as pleased with their grip. They seemed to drift a little too much on the curves. I may need to to play with the pressures as I still have them at about 20 psi. But they were a godsend when you're stranded on the road.
    I just ordered a Kumho replacement and a couple of the Federal Formozas for wifes F3T from Walmart so that maybe I can count on them on the road..
    Completed the trip with the Nankangs and just lost a day but beautiful country after the sun came out
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Jun 2014
    ny
    Quote Originally Posted by MikeT View Post
    Mike
    i will never own runflat tires produced under current quality. major problem they cause dents & cracks in rims
    and have a much higher rate of bubbles. AAA agrees with me on this whole heartedly.
