Results 1 to 8 of 8
    Active Member SuperDave_GPS's Avatar
    Mar 2016
    Kingston, Ontario, Canada
    Default Sudden Drop in Fuel Mileage
    Typical mileage on a full tank of fuel on my '16 RT Ltd is around 350+ Kilometers per full tank (about 220 Miles), regardless whether I run premium fuel or regular.
    I haven't checked to see if any codes have been stored, but during both days of this past weekend here in Ontario Canada, my mileage on a full tank has dropped to about 275 Kms per tank.
    Tire pressure is confirmed.
    It seems to ride fine, other than sucking back more fuel than normal.
    I doubt the drop in outside temperature has anything to do with it (temperature only went to about 10 degrees Celsius over the weekend, which is about 50 F), as I never noticed this issue this time last year.
    Just wondering if anyone may have some suggestions before I start to go too crazy with looking for things..
    Thanks.
    SuperDave_GPS
    "Rosie"
    2016 RT Limited
    I do notice a drop in mileage when the weather turns cold. Not sure of the actual causes though.
    Another possibility--have your gas station(s) changed over to "winter" blend? That is another cause if we are not considering any actual mechanical issues.
    Bossier LoUiSiAna
    Try adding some fuel treatment octane boost at your next tank & good luck
    Default One more check....
    If your air cleraner has not been change in some time or washed if it is washable it will help. Also check if there is anything blocking the air intake....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    indpls in
    Default windy
    was it windy out riding into a head wind will kill your mileage
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    winter fuel lest miles
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Mar 2016
    Default Thanks Everyone
    Thanks for all your ideas / suggestions, everyone.
    Last weekend I did have to replace the left-hand fog light bulb (what a pain in the a$$ that was).
    As it was the left-hand side, I did have the air intake in the way, so maybe I may have knocked something out of place while fighting with the light assembly to get it all back together.
    As for the filter itself, that was replaced just this past winter, so more than likely it's still good.
    Thanks again everyone..
    Cheers from Canada.
    SuperDave_GPS
    "Rosie"
    2016 RT Limited
    If it's not the air intake...
    Temperature most assuredly affects fuel mileage...
    As does the introduction of Winter blends for the fuel that you're using
    Other factors
    Tire pressures
    Tire alignment
    Belt alignment
    weight...
