Results 1 to 6 of 6
Hybrid View
    Active Member almosthere's Avatar
    Jan 2016
    Paw Paw, Michigan
    Default need help screw size?
    I am putting the primary muffler back on my 2015 RT-S SE6 and am missing the 3 small screws that hold the plate with the 2 front rubber hangers. Can anyone tell me the size that I might be able to pick them up at the hardware store? Or are they a speciality item only obtained at the dealer, if so what the part # might be?
    Faribault, MN
    From Cheapcycle parts, under the 2015 RTS SE6, Exhaust parts breakdown,
    https://www.cheapcycleparts.com/oemp...exhaust-system
    Hex. Forming Screw M6 X 20 Part # 210262050
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2016
    Paw Paw, Michigan
    thank you much
    So if I get 6mm x 20 at hardware store they should work?
    Faribault, MN
    Yes they should, I don't think there's any variation on thread pitch with Metric bolts at that size.
    Safe Rides,
    IBA 70020
    Jan 2016
    Paw Paw, Michigan
    Thank you again will get those in the morning.
    Jan 2016
    Paw Paw, Michigan
    Ok got the screws and was tight but got the front hanger plate re attached. primary muffler, (cat.), slid into front hanger rubbers fine. NOW how do you get the top rubber hanger to slide on to both hooks? I can slide it on to one or the other but can't seem to stretch it to go over both. Then it looks like the inside spring is going to be almost impossible to stretch to attach.
    HELP Please!
