Results 1 to 5 of 5
    Nov 2014
    Austintown, Ohio
    Default neither key is working
    neither key will start my friends 2011 rt. What could be the cause. Is it the battery. Does it need to be reflashed or does he need a new set of keys.
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    Does the key turn in the switch?
    Does the dash light up?
    Does the starter make any clicking noise?
    2017 F3, SM6-basic black, plain and simple
    Nov 2015
    Chardon, OH
    Is the Kill Switch in the RUN position?
    Does the center display say Bad Key?
    Is this DAZ's machine?
    If it is a Bad Key situation, as you and he search the forum for answers and receive responses, please remember that BRP rolled out a new DESS design in 2014. Information you find from that time frame about those machines - and there's a ton of it - about operation and part numbers, etc, won't be applicable to the 2011.
    Doug
    ”Freedom is not a loophole”
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    does the dash light up?
    Double check kill switch I've accidentally hit that before and did not realize it.
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Default all of the above....
    Little more information will get you what you need.
    ​2012 RS sm5
