Thanks Thanks:  4
Likes Likes:  4
Results 1 to 5 of 5
    Oct 2017
    N.E. Ohio, USA
    Default Jinxed Myself!!!!
    You guys gave me good advice on the vacuum lines. Thanks.......................
    Next day, after I stopped after a short ride and tried to start. The screen said: BAD KEY
    Eventually it started. A few hours later using the other key, when I tried to start it. BAD KEY.
    Put it on the trailer Bad key before loading. It has started every one of the twenty times since. Still on trailer.
    Battery reads below 12 volts.
    So is it just the battery? Probably a new battery tomorrow. Don't know how old it is.
    Falling off motorcycles for over 50 years.
    NE Ohio, USA
    Very Active Member trikermutha's Avatar
    Sep 2014
    USA
    Try charging it first to be sure. Not sure how long your Spyder been sitting?
    If sitting awhile may just need a charge or take to battery place and have tested.
    Nov 2015
    Chardon, OH
    Don't know how old it is? Original maybe? New battery tomorrow sounds like a good idea.
    Doug
    2012 Spyder RT LTD Lava Bronze, RT 622
    Original Owner
    Seal Pups, F4 Customs SWCV, Corbin, JT's Air Filter, Cat Bypass, Power Commander V, NBV, SpyderFlap, Rivco Dual Flag Holder, Lidlox, Baja Ron Sway Bar, links, plugs and wires, Adjustable Chrome Side Vents, Spyderpops Block Off Plate and Belt Guard, Bump Skid, Canisterectomy, Akrapovic, TricLed HL/FL, Spyder Cuff with X-Grip, S-Drive, Rock Armour, P238, Laser Alignment by Gray Ghost, Windshield Arm by Noboot, Vibration Dampener by Doc.
    Default ooouch!!!
    There have been a lot of DESS codes that require replacing the ignition switch. They do start with the hit and miss but eventually go bad. Have it checked out with the dealer. Low battery does not give a bad key warning....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2017
    N.E. Ohio, USA
    After I got it on the trailer to haul to the dealer the dang thing fired up. With both keys. Every time. But I hauled it to the dealer the next day.
    The machine showed NO codes. They updated the ECU and installed a new battery. The tech said he has seen a low battery cause that problem. So all is fine for now.
    On the bright side: I brought two pieces of vacuum line cut to length with me. Since the tech had that left side off he installed the new vacuum hoses for me. No charge.
    NE Ohio, USA
