Thanks Thanks:  5
Likes Likes:  18
Results 1 to 20 of 20
    Aug 2017
    Wisconsin
    Default Tire report offered and needed
    I spent last winter researching an automotive rear tire for my 2017 F-3L. I settled on a General Altimax, pumped it to 18 psi cold, and rode it two up all summer, mostly in dry weather. The tire worked great. After 6,000 miles, it shows very little wear and has performed perfectly.
    Now, with 16,000 total miles on the bike, lím looking for front tire recommendations. I would like to hear from you if youíve run car tires on the front for a season. Iíd like to know what you bought, what psi you use, and how the bike handles. Does it steer well? Does it hold the road on curves? Does it shed water or hydroplane?
    I would appreciate hearing from the voice of experience.
    Sep 2016
    Jackson, MO - formally Yukon, OK
    Default Front car tires
    2016 RTL- I am running Yokohama Avids S34FA on the front 2 wheels. (175/55/15) 18 PSI
    They stick like glue, are great in rain and wet roads. Stick to road going around curves. Brake clean and straight. Right now I have probably 5,000 to 6,000 miles on them and they look almost new. I expect I won't get as many miles on them as I did on my Kenda's because the Yokohama tire is a softer rubber.
    My first set of post OEM Kenda's were Federal Formoza. The tires were not sticky but did brake clean and straight. I had an issue with them pushing me sideways on the wet roads. After about 1,000 miles I took them off and installed the Yokohama Avids. In my opinion I do not want to risk my life for just an okay tire. My tires have to do what I want them to do and still be the kind of tire I need them to be.
    I am running a Yokohama S Drive on my front tire with the same kind of performance as I get from the Yokohama Avids.
    If I decide to try another tire it will be the Vredestein tires.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Re front tires
    Quote Originally Posted by Jambo Creek View Post
    2014 RTS Continental Procontact 175/55/15 overall great in every aspect over 23000 miles so far tread depth at 8/32 running 16lbs stick like glue in corners hope this helps
    Very Active Member trikermutha's Avatar
    Sep 2014
    USA
    Federals. Two seasons now on them and still are like new
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited. Federal Formoza on the front in stock size, much smother and better handling than stock 20 psi. 14,000 on the rear General Altimax at 22 psi.
    2012 RT Limited (Traded)
    2016 F3 Limited
    2010 Vulcan Voyager
    2014 Suzuki V Strom 650
    Apr 2012
    PA
    Vredestein all around. Only 70 miles, dry road. The ride is awesome! Like riding on a cloud, very cushioned. Easier steering, excellent braking. Running 22 lbs in all three. Will experiment on that. Tom
    "I am the guardian of lost souls! I am the powerful, the pleasurable, the indestructible Mushu!"
    2016 F3Limited Intense Red Pearl
    Lamonster LED headlight and fog lights, Custom Dynamics LED fender and saddle bag lights, Can Am hitch, Can Am rider and passenger backrests, Baja Ron sway bar and Lamonster dog bones.
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    laugh if you want but 2 years ago i bought 2 weatherguard 175/65/14 winter tires from walmart and they installed them on the front of my 2010 rts .Not sorry that i put them on now have 28000 klms 0n yhem ,no wear showing and steering is much improved, wind doesnt bother as much on road .got them as a spring sale ,tires installed and balanced for under $100.00
    Harrington, Australia
    ..... thatís me laughing, Gordy
    Seriously though, this just goes to prove that there is no ďrightĒ tyre for everyone. The suggestions on here are great as they give you a selection and an idea of performance, but we all need to find our own solution for our personal needs, including the much maligned Kendas. There are so many factors involved here like road surfaces, cambers, riding styles, weather etc etc etc, that the perfect tire for one rider may not work for another simply because of where they live. Unfortunately, that may mean writing off a fairly new tyre that you thought would work for you, but since itís possibly your life you are risking, I believe thatís a small price to pay.
    Quote Originally Posted by Gordy View Post
    2016 F3 Limited - Setup for Tall.... 6'7", 330lbs, 38"inleg.
    Lamonster RIP Boards in Position#5
    F4 25" F3-L screen fitted to Madstad adjustable hardware.
    Russell Daylong custom seat with driver 1.5" rearset, 1.5" taller
    Lamonster Billy Club handlebars
    ECU Xtreme Stage 2 retune
    Bajaron Stabiliser Bar
    Wilber 630/640 shocks
    Kuhmo KH17 175/60 fronts-18psi / KU22 205/55 rear-20psi
    SpyderLovers Sponsor SpyderAnn01's Avatar
    Jun 2010
    Las Vegas
    I am running the Federal Formoza on my 17 F3T and with 40,000 miles on them they are still great. They handle perfectly in the rain, and Iíve been riding in some real frog floaters lately. They have a better wet traction rating than the Yokohama too. I also ran them on my 14 RT and liked them as well on that model.
    2017 F3T-SM6 www.TricLEDUSA.com Lights, Wide Vu Mirrors, BajaRon Sway Bar, Spyderpops Bumpskid, Roadster Renoí Belt Tensioner, F4 Customs 21" Tinted Vented W/S, PPA Black Orb Wheels www.PPAWheels.com, Russell Day Long Saddle
    2014 RTL-SE6 on test drive 8,600 miles
    2011 RTS-SM5 loaner put 5,000 miles on it
    2010 RTS-SM5 retired at 59,148 miles
    2010 RT- 622
    Jun 2010
    Las Vegas
    Quote Originally Posted by Tango View Post
    I am sorry but 70 miles isnít enough to give a review. Thatís not even half a tank of gas or an hour of riding.
    2010 RT- 622
    Northern Kalifornia
    Default Federal Formoza & General Altimax.....
    Formoza's with 8k+ and Altamax with 7k+ all with 18 psi cold and no issues so far.
    May 2017
    Mesa, Arid-Zone-A
    Federal Formozas for me. Don't know about them in the rain as I haven't been in rain. (Live in AZ) They have 12K on them and I can't tell any wear. They look new to me. Keep them at 18PSI. Traction is like riding on rails.....
    2014 RTL Platinum Silver Satin, BRP Driver Backrest. Baha Ron Bar, Elka stage 2 Shocks, Lamonster Hiway pegs, Lamonster Bump Skid, Centramatic Wheel Balancers, Tricled Wide Vu Mirrors, Third Tail/Brake light, Missing Belt Guard, Federal Formoza front and General Altimax rear tires, Squared Away, Full mirror turn signals, Foam handlebar grips, Doc Humphreys Vibration Damper, Matching Platinum Silver Satin RT622 Trailer.....Semper Fi.....
    neepawa manitoba ca
    by the way i run a general altimax on the back this is my second one, run 24 lbs .No one seems to be able to balance our rear tires so I built my own balancer but the general only needs maybe about 1/2 an ounce
    Active Member Rattlebars's Avatar
    Mar 2017
    Now, with 16,000 total miles on the bike, l’m looking for front tire recommendations. I would like to hear from you if you’ve run car tires on the front for a season. I’d like to know what you bought, what psi you use, and how the bike handles. Does it steer well? Does it hold the road on curves? Does it shed water or hydroplane?
    What size Altimax? I can't find an Altimax 225/50R15 or Vredestein tires in the stock rear size on tire rack.
    May 2016
    Quote Originally Posted by Rattlebars View Post
    215/60/15 General Altimax RT-43
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Like Peteoz says - everyone rides different
    "There are so many factors involved here like road surfaces, cambers, riding styles, weather etc etc etc, that the perfect tire for one rider may not work for another simply because of where they live."
    The fronts seem to be getting better on the OEM Kendas, so no worries for us until we get the wear out of them at about 30,000 miles plus.
    Since then we have had 3 sets of Kumho Solus KH16s in the 155/60R15 size and have been very pleased with the handling, roll and grip in dry and wet conditions. We run them at 17 psi on the F3T and 19 psi on the RT making sure to keep them equal side to side.
    However on our last trip I hit a rock and blew the sidewall on the right Kumho and couldn't get a Kumho at the Show Low AZ Discount tire shop (nearest supply was either Nevada or Dallas TX). I do feel that the heavier sidewal and carcass of the Kumho prevented damage to the wheel and allowed me to roll about two miles to a wide spot where I could pull over safely.
    The Discount tire shop had a set of Nankang AS-1 tires in the same 155/60R15 size at $61 a piece so I now have run them about 1000 miles with good roll and balance, but am not as pleased with their grip. They seemed to drift a little too much on the curves. I may need to to play with the pressures as I still have them at about 20 psi. But they were a godsend when you're stranded on the road.
    I guess that I'm open to most suggestions on a front car tire replacement but will be looking also at what Walmart might carry so that I can secure a replacement if needed while on the road..BlownKumhoafterRock.jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT, 15 RT-S, current 15 base RT and F3T
    Aug 2012
    Central Coast, CA
    For the front, I'll also give another vote for the Federal Formoza. Stock sizing is a nice bonus, since you don't have to wonder whether it'll fit your fender or not.
    This is my fourth set of front tires over 2 different models with a collective about 75k miles and they're the best I've found so far.
    Thanks to Ann and Joe for the recommendation.
    2014 RT SE6
    Previously 2008 GS SM5
    Apr 2012
    PA
    No need to get snarly. My post said it was only 70 miles. Hour and a half of riding back roads. Our speed limits are no where near yours. Tom
    May 2016
    Really I have the same tire General Altimax I run 18lbs 24000miles at 4/32 also use a centramatic wheel balancer runs perfect
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Another vote for Continental Contiprocontac 175/55/15 size. Running 15lbs and has transformed the Spyder to a much better handling machine than stock, both wet and dry weather. 10,000 miles and still look like new.
