Results 1 to 11 of 11
    Oct 2017
    N.E. Ohio, USA
    Default Vacuum lines on 2011 RT-SM5
    Vacuum issues? Nope, she's running fine.
    But I understand it's common to replace the vacuum lines at some point. Can you steer me to where to get them? Is there a kit? How many individual hoses? A video or other instructions?
    I want to put them in stock and be ready for the inevitable.
    Thank you.
    Ride safe!
    2018 Spyder RT Limited
    Nov 2015
    Chardon, OH
    Hey Daz. Well, you don't want to buy the OEM parts because it will be the same crap as you already have. Purchase high temp silicon vacuum hose from NAPA, Summit Racing, etc. If you live anywhere near Chardon, PM me and I'll just give you some. You'll have to buy way more than you need. Otherwise, purchase hose that is 3mm ID, and you cut each line 85mm long.
    Pull off the left side panels and look for the MAP sensor. Lines are on each side of it. The front one is a pain and a pair of forceps can come in handy if you have big hands. There's a barb on the fitting at the manifold end of the hose, so it can be difficult to get that end off. Just keep twisting and it will come off eventually. If you have the original lines still on, then they can go any day now. Good idea you have to be prepared.
    Doug
    ”Freedom is not a loophole”
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    At most you will need about a foot.
    Nov 2015
    Chardon, OH
    Quote Originally Posted by OlJim View Post
    Jim, my meaning was that it's hard to find the product packaged in a short length. Therefore, you're forced to buy way more than you need. Thanks for keeping it straight. I edited the other post.
    Doug
    Apr 2015
    Grand Forks, ND
    Default Hose
    I had my 2012 RTS at a dealer for 3 weeks while they tried to figure out why it was running bad. I finally told the service writer to replace the hoses and it fixed my problem.
    Jim
    Nov 2015
    Chardon, OH
    Quote Originally Posted by JimboRTS View Post
    Jim
    An excellent example of why they aren't called Service Advisors anymore. We have to tell them what to do.
    Doug
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    Mine went out when at the 3-wheel ralleye in S,D, The BRP dealer in Spearfish S,D, replaced them, very good dealer. They keep the hose in bulk.Other dealers possibly keep it in bulk and would sell you just the amount you require. My old hose came out in pieces.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    Oct 2017
    N.E. Ohio, USA
    Thanks to all for the information. Now do you think I jinxed myself for thinking about it?
    Snowbelt I live in Deerfield where we used to have a gas station about 20 years ago. Not too close to anybody!
    Thanks.
    Ride safe!
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by daz View Post
    Thank you.
    If you look in the below link I have posted color pictures before. They are the 2 orange looking tubes in the pics.
    I bought my hose from NAPA. It was cheap. Just remember to cut the lines to the same length as the ones you are pulling off.
    http://www.spyderlovers.com/forums/s...t=vacuum+lines
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Oct 2015
    Lynden, WA
    Thank you.
    Recommended replacement is Napa part number H466 silicone hose.
    Need 2 pieces 85-88mm Long with a 3 mm ID.
    http://www.spyderlovers.com/forums/s...ht=vacuum+hose
    On Sunday I bought this hose in a 3m package for $7.99.
    Plan to replace the hoses on my ST asap.
    Send me a PM with your address and I'll send you 1 ft.
    Cheers, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Oct 2017
    N.E. Ohio, USA
    Quote Originally Posted by Haze View Post
    Cheers, David C.
    Geeze thank you David! I'll just go to my local Napa and get it. You are very kind!
    Ride safe!
