Results 1 to 7 of 7
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default RT Seat Release Emergency Solution
    Last week I had a situation where I could not get my RT seat to release from the locking pin. I resolved the problem with little chance it will happen again, but it scared me and I decided to figure out an emergency release solution. I believe I have one and it works when tested. Thus I'm sharing with you.
    I used a small gauge solid wire and connected to the seat latch mechanism through the same gap that the factory wire goes through. I then ran the wire through an opening around my oil dipstick/filler. On the other end of the wire I attached a small pull ring. It needs to be long enough to get to it in an emergency, but I don't want it too long to be unsightly. I route the wire around the oil filler tube to help in releasing as you want the wire path to be as straight as possible. In testing I am able to open my seat either with my key or by pulling on my emergency pull ring.
    Rob
    Seat-1 Wire to latch.jpgSeat-2 Wire routed to oil check opening.jpgSeat-3 Wire with pull ring.jpgSeat-4 Finshed job.jpg
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    I might suggest protecting that beautiful red paint with something in the steel wire.
    Lew L
    2014 RTS , Circuit Yellow
    Feb 2017
    Good straight forward idea and an excellent safety backup. Insulated multi-strand wire I'm guessing. We've done something very similar to our 1974 Triumph TR6 whose hood (bonnet) release is notorious for eventually breaking.
    I can't help but wonder if, some day, someone your RT will say, "I wonder what this is?" and give it a pull?
    Jul 2017
    Massachusetts
    I've read where others have just removed the pin completely. I've been thinking about doing it myself.
    2017 Can-Am Spyder RT
    Apr 2015
    Tucson, AZ USA
    Default If you remove your pin
    Just keep in mind that if you remove your pin and you trailer your Spyder, your seat will likely float up in the wind.
    By the way, I ended up removing the steel ring from the end of the wire and just made an ending loop in the wire that I can get my finger in. This makes the wire not visible at all and I have little risk of any kind of paint rubbing.
    Rob
    Quote Originally Posted by imfleck View Post
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default Seat release
    Just curious: Is that a common issue with the RT? I have a 2018 RT and wondering if I should do something like that?
    2018 RT Limited "Blondie"
    Apr 2015
    Tucson, AZ USA
    I don't think it is a big problem, but I've heard a few people experience some sort of issue with lifting their seat. The greatest risk is you can't fill your fuel tank if the seat won't come up and you don't have a gas access fuel door installed on your seat. I did not want to have an issue while traveling when I could create a simple emergency solution.
    Rob
    Quote Originally Posted by Bigmo View Post
Tags for this Thread
