Well, he gave up trying to fix it and got a lift ....
2014 RTL Platinum
Well, when you're stranded on a corner in Winslow, Arizona, it's tough to get into it too deep. Once he finds out what the issue was, I'd be interested.
Doug
”Freedom is not a loophole”
I just got home and did not see this thread until now. Sorry I could not help. I would like to know what he finds out. Tomorrow, when I have more time, I will take a look at the codes and make a guess.
+1 on the battery, Have it load tested, My '13's battery died last year and I was getting all sorts of weird codes and behaviors. someone here got me to check mine, and after a new battery, haven't had another electronic issue yet.....
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Also late to the party....
U0100 Lost communication or CAN-BUS ID.. (Controller Area Network)
U0122 same as U0100
U0073 CAN-Bus failure CAN-Bus off
C006C communication intermitten /erratic sometimes triggered by U0122
Blown VCM fuse
Just for the record... 'ing to see what they find if more than a computer reset....
now i know !
okay now , I know this can`t be the purdiest girl in Winslow Arizona , but it is a flat bed ford !
2014 RTL Platinum
