Page 1 of 4 1234 LastLast
Results 1 to 25 of 92
    Dec 2015
    Oakley Utah
    Default 2014 RT stranded in Winslow, AZ
    My friend from Arizona is dead in the water in Winslow, AZ. 2014 RT
    The codes he pulled are;
    U0100
    U0122
    U0073
    C006C
    Is there something he can do to fix the fault and get back home?
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    Has he checked his fuses yet?
    Doug
    ”Freedom is not a loophole”
    Dec 2015
    Oakley Utah
    I don't think so. I'll suggest that. Do you know which ones and which fuse box?
    2014 RTL Platinum
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    A quick Google search found this about 2 of them.
    C006c is in the ECM module
    It is a VSS CAN message plausibility error
    Caused by communication intermittent/erratic and/or Check Sum Error.
    External troubleshooting is not possible, check for communication fault.
    UO122DPS is in the DPS module.
    It is a loss of communication with the VCM (loss of CAN ID's.)
    Caused by VCM fault active. Damaged circuit wires, damaged VCM or damaged DPS/VCM pins.
    Action..Check for VCM fault.
    Disconnect MPI2 from DLC connector.
    Measure resistance between DLC-1 and DLC-2 (expected value = 50-70 ohms.)
    Measure resistance between DLC-1 and ECMB-C1 (expected value < 2 ohms).
    Measure resistance between DLC-2 and ECMB-C2 (expected value < 2 ohms)
    Bob S
    Nov 2015
    Chardon, OH
    I looked up the codes in the app and they all are electrical / CAN Bus in nature. I don’t know which fuse but the descriptions in the owners manual should give a clue. I don’t have schematics. Maybe Billy will find this thread and can ferret something out.
    Doug
    Oct 2014
    SD &AZ
    On a lighter note, have him look for "A girl my Lord in a flat bed Ford". Sorry couldn't resist. Good luck.
    Bob S
    Dec 2015
    Oakley Utah
    Quote Originally Posted by GOZFST View Post
    He said he's on the wrong corner!
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    He is checking them. He thinks it might be a relay, but I didn't see any reference to a relay in the code descriptions.
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    You know how those fuses can be hard to see. Remind him that he may have to pull them to get a good look.
    Doug
    Have him look for damaged wires, like maybe the harness on the swingarm having come loose and rubbing on the tire. If there are no blown fuses and no damaged wires the the most likely suspect is the VCM, vehicle control module. If it's bad I think that would be a first here on SL.
    Mar 2013
    Something else to consider is the battery, if it's low on voltage it can cause all sorts of codes. Is it the original battery? Ours only lasted 3 years on our 14 RT.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by PW2013STL View Post
    I agree when it’s electrical check the battery and it’s connections.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Good to see friends helping friends here. Anything beyond what I have seen so far is above my pay grade.
    Hope he gets it figured out.
    Dec 2015
    Oakley Utah
    Well, he gave up trying to fix it and got a lift ....
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    Well, when you're stranded on a corner in Winslow, Arizona, it's tough to get into it too deep. Once he finds out what the issue was, I'd be interested.
    Doug
    Jul 2011
    Mitchell, Ontario, Canada
    I just got home and did not see this thread until now. Sorry I could not help. I would like to know what he finds out. Tomorrow, when I have more time, I will take a look at the codes and make a guess.
    Faribault, MN
    +1 on the battery, Have it load tested, My '13's battery died last year and I was getting all sorts of weird codes and behaviors. someone here got me to check mine, and after a new battery, haven't had another electronic issue yet.....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default Also late to the party....
    U0100 Lost communication or CAN-BUS ID.. (Controller Area Network)
    U0122 same as U0100
    U0073 CAN-Bus failure CAN-Bus off
    C006C communication intermitten /erratic sometimes triggered by U0122
    Blown VCM fuse
    Just for the record... 'ing to see what they find if more than a computer reset....
    Sep 2016
    clark county indiana
    Default now i know !
    okay now , I know this can`t be the purdiest girl in Winslow Arizona , but it is a flat bed ford !
    Dec 2015
    Oakley Utah
    Good one
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    He recently had the compressor and air bag replaced. Might have happened then.
    2014 RTL Platinum
    Default I know this isn't helpful...
    But it's the best I can do for you!
    Mar 2015
    forrest above Reno, Nv
    From the you tube vids after the Eagles , about strange lonely cities:
    We were in Tonopah last week on our way to Vegas.
    The "Clown Motel" is a must see.
    Lew L
    2014 RTS , Circuit Yellow
    Jul 2011
    Well all the codes are Can Bus communication errors of some kind. Multiple modules involved. So damaged or shorted Can Bus wires. That could come from some recent work being done. If nothing done recently. Then I would look for water in one of the connectors.
    Invalid Emails
    May 2011
    Scottsdale, AZ
    Default Still do not know!!
    So..I see that my friend UtahPete told every one here about my ordeal in Winslow AZ. It started the day before: twice I got the dreaded Limp mode. Took the key off, waited some time and it started again... Being a good catholic boy I said: "I must has touched the brake while the throttle was open"! Double sin: I knew I did not do that and just lied.
    Related or not: the bike was starting with a more diesel sound than normal, almost like a cam chain loose before the hydraulic chain tensioner get in function (on a "normal" bike). It started again yesterday after 90 miles at a good clip and went on every 5 to 10 miles after this I decided to limp to Winslow all the way from 2nd Mesa.
    As this happened to me a year ago I kind of think it is one the big relay by the fuse on the left side: I did not check it (what for...did not have a replacement!!) but I am sure it was burning hot like last year.
    Twice in one year on a flat bed.... I am trying to be tired of my -14 and as the -11 I had before was not stellar either so... I am starting to think about life without a Spyder....
