Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Bike to neutral
    Active Member meerkat's Avatar
    Jul 2015
    leesburg florida
    Default Bike to neutral
    Has anyone noticed that the bike , the RT , shifts into neutral when coming to a stop . It only does this about 5 persent of the time , but it is aggrating when the light changes , and you are in no go mode . I am verry careful to make sure I do not toutch the brake petal ,so thats not the problem . This did happen on my last RT also . Anyone else experience this?
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by meerkat View Post
    The only time mine has done that is when I am listening to music. I though thats a strange coincidence. Then I figured it out. I was tapping my fingers on the grips in time to the music and bumping the paddle every now and then.
    Moved my hand away from that grip at Lights and then back as I take off and it has never happened again.
    2020 RT Limited , Petrol Blue
    May 2017
    Mesa, Arid-Zone-A
    Never
    Semper Fi
    Jul 2017
    Woodbine, Iowa
    I have a 2015 and it has never did it.
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    2018 rtl and it has never done this.
    2018 RTL , dark blue
    Mar 2016
    Willis, Michigan
    My 2015 RT-S has never done this. It does, however, have the peculiar habit when I'm slowing down of timing a downshift as I bump across a RR track. It seems the mild concussion causes it to shift slightly earlier than it otherwise would.
    2015 Sypder RT-S SE6
    2016 Polaris Sportsman 570 ATV
    2003 F250 SuperDuty
    American Saddlebred Horses
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    2014 RT-S SE6 here, and never has this happened. I’m thinking that you must inadvertantly be touching the paddle. JMHO WTFDIK
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Nope.My 2012 RT never has.
    Bob S
    Aug 2016
    Cleveland, Ga
    Default Doesn't shift to neutral.
    Quote Originally Posted by gerald37 View Post
    Mine has started to not shift to neutral when I shut off the ignition. It will not shift to neutral when I try to start it so it will not let it start unless I use the foot brake. Any ideas?
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by joekeys View Post
    Mine has not ever shifted to neutral when I shut off the ignition. If it is in 1st when I turn off the ignition, the next time I turn on the ignition it is still in 1st. When I then press the brake pedal and start the engine, as soon as it starts it automatically shifts into neutral. It's been doing this unfailingly for 46K miles. That's what it's supposed to do. If I want it to be in neutral once I've shut off the engine, I must shift it into neutral before I shut it off.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2008
    MA & NH
    Not ours. (shifting to neutral at a stop) I'd say something is up, not a desireable tendancy. We're starting to talk about 2 different things ?
    Oct 2016
    Faribault, MN
    Never on my '13 in 24,000 miles. +1 on maybe inadvertently downshifting manually somehow?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2010
    Las Vegas
    All of my Spyders have done that almost every time I stop.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Idaho
    What JayBros says. You're seeing normal behavior.
    2014 Copper RTS
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    My buddy and i, we both had 2014's and it would happen every now and then.
    Buddy upgraded to a 2017 last year and it also does it sometime.
    I now have a 2018 and it has not done it yet.
    2018 RT LTD , Black
    Dec 2013
    I can get my 2013 RT (& some other SE's too!) to disengage the clutch while at reasonable speed by rolling the throttle back until the engine is in a 'neutral throttle' state, where the finely balanced revs mean it's not driving OR engine braking.... and if I slow then coast to a stop with a neutral throttle like that it can sometimes shift the box into Neutral.... Not that I do this often, but when I do it can be a bit annoying sometimes, cos once the clutch disengages, the computer doesn't readily let you re-engage any gear while your SE is moving at anything more than a few mph!! I suspect this 'neutral throttle clutch disengage' thing is what's happening to you meerkat, and then once or when that happens, the computer 'tries to guess' what your lack of definite control inputs might be leading to, so it sometimes erroneously selects Neutral as you gently let your SE coast to a stop without the clutch engaged....
    Simple solution I've found tho (especially since the gearbox actually IS still a manual gearbox, only with the addition of a computer controlled auto downshift fail-safe & a Centrifugal or Electro/Hydraulic clutch) is to just use the flappy paddles as they were designed & intended to be used and actively change down thru each gear as you slow until you are in first; and then use your foot on the brake pedal to come to a complete stop & hold it there! By using the paddles and changing down, you are effectively retaining control of your vehicle the whole time and not leaving the computer free to bring that 'fail-safe downshift' followed sometimes by a 'best guess change into neutral' thing into play....
    While it's a pretty good thing and even pretty good at what it does, the computer is quite simply, not as smart or adaptable as a person can be; it can only work with what it's been programmed to do, & if you don't clearly indicate what you intend by using the controls you have access to in order to tell it, then sometimes it's gonna get it wrong! Use the flappy paddles to tell it when & where to change down - it won't let you damage anything if you try too soon, and it'll always know you want to go 'down' rather than into neutral when you stop, cos that takes a different paddle movement! And if you get it wrong every now & then & haven't changed down when you should've, it's even got a 'fail-safe downshift' programmed in to save the engine, clutch, or gearbox from any potential damage!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2013
    SF Bay Area
    The Semi bikes go into neutral when you shut the engine off even if it was left in 1st. Can't figure out how to pop it into neutral while moving. Don't think it can be put in neutral if you're not using the brake pedal. Not sure about the earlier RT's though.
    2021 F3 Ltd , Magna Red
    Idaho
    Mine doesn't, and never has. If it was in gear when I turned the ignition off then I have to depress the brake in order to start it. Then, in an instant it shifts into neutral. If I put it into neutral before turning off the ignition it will start without depressing the brake.
    2014 Copper RTS
    Jul 2017
    I agree. Mine is the same, and once home, and safely in the garage, I do shift it into neutral prior to shutting it off.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    2010, 2014, and 2018 RTs...
    They all stayed in gear; until I put them into neutral.
    Oct 2013
    Wood Village OR
    Between my wife and we've had 4 RTLs and none of them have done that.
    2014 RTL , Black Currant
    Feb 2012
    Spring City,Utah
    SOP standard operating procedure.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2011
    Mitchell, Ontario, Canada
    SE models cannot shift themself into neutral after the key is turned off. Also cannot shift into neutral before starting the engine. It is just impossible. The HCM uses hydraulic pressure to shift the gears. That hydraulic pressure is provided by the HCM oil pump. The oil pump is driven by the engine. When the engine is not running there is no oil pressure.
    The requirement for your foot to be on the brake pedal when starting in gear or the ECM will not allow the starter to work. Is an extra step BRP programmed in. I will guess was done for safety reasons. Maybe in case there was a stuck clutch.
    2018 F3 LIMITED
    All four of the SE's have never went into neutral when downshifting to a stop. I let the do the downshifting on the SE's and it always stops at first.
    Neutral can be shifted into with a very gently tap on the reverse paddle for 1 to N. Or...from reverse to N then a very gentle tap on the + paddle.
    Mar 2016
    Palm Harbor, FL
    Maybe the hydraulic actuator is not fully ingaging the transmission into gear. After engaging first,go down (you might need a wench) see if you can move the lever farther towards engage. If you can might be why it can bounce back to N.
