Results 1 to 11 of 11
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Default Key won't turn to open frunk
    Hello guys and girls, been away for some time but i'm back as good as ever and twice as ugly
    For some reason the key will not turn to open the frunk, for some time it opened, it was hard to turn but it did open, last week i tried to open it and it did not work anymore, i pulled the side pannel off and pulled on the cable and opened that way, oiled the latching mechanism and tried to turn the key,,, nothing, looks like the problem is under the switch.
    I searched for answers but everybody keeps going round and round about it with no concrete answers, does anybody know how to dissasamble the switch to repair the issue without giving a mile long explanation of why it should work or without saying look at the manual?
    Thanks in advance
    Mar 2008
    Hesston, PA
    Default my suggestion
    Did you try pushing in on the top of the lid and turning the key at the same time???
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Quote Originally Posted by larryd View Post
    Yes, many times, also tried turning the key with the frunk open and it will not turn, i can open it by pulling on the cable from under the plastics closer to the latching mechanism but not from the switch, turning to open the gas lid works but not for the frunk
    Bossier LoUiSiAna
    Quote Originally Posted by Mexican View Post
    Thanks in advance
    welcome back
    try some
    Graphite spray lube in the keyhole ,insert key work it around few times,& repeat , the cable might need lube too
    Default Bummer.....
    If it turns smoothly then it may be disconnected if it does not turn it may be jammed. At any rate you need to get the switch out to get to the bottom where the cables are connected. Does the seat latch work..? Not near my manual to see if it shows the workings ...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Seat latch works good, key turns good, only when i try to turn it to open frunk it will not turn
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    welcome back
    try some
    Will buy some tomorrow, worth to try
    Default Try This....
    Open the frunk...disconnect the cable from the latch and try to push it back and forth and try opening with the key while holding the end to see if there is movement. If you have a cable luber you can lube it from there. This will save going into the ignition switch but if not you will have to go there to see if something has come undone or broken...
    ​2012 RS sm5
    Dec 2016
    Nj
    Default the problem was the key itself!!
    or rather the key holder that is sold --the plastic casing was too oversized by millimeters , and needed to be shaved down away from the metal--wondering if you tried your second key?
    Thanks in advance
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Quote Originally Posted by Petrom714 View Post
    Yes, i have tried the second key and still dont work
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Already tried all of the above, i guess something has jamed or broke under the switch
