Results 1 to 16 of 16
Thread: sway bar
    Active Member msherwood's Avatar
    Sep 2013
    Manteca, CA
    Default sway bar
    I have a 2013 RT limited, It has the stock sway bar on it. Does anybody know if the reason to replace it is because of safety issues or is it just better handling with a Baja Ron sway bar.
    Thank you for any feedback
    Active Member Jarred's Avatar
    Jul 2018
    Long Island NY
    Quote Originally Posted by msherwood View Post
    The BajaRon swaybar is thicker than stock, so better handling. Plus, BRP uses plastic links, BajaRon’s come w metal links. One of the best aftermarket parts I’ve put on my Spyder, you notice the difference immediately. Hope that helped.
    2018 RT Limited Metalic Champagne
    US Spyder Ryders Long Island NY Chapter
    2018 RT Limited , Metallic Champagne
    Oct 2016
    Faribault, MN
    Just Better Handling, though I can also heartily recommend his shock adjusters for 2013's.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2015
    southern WI
    Ride it for a while....you might find that you like it just the way it is...many do. The BajaRon bar is a nice addition, but maybe not necessary. If you know anyone with a Spyder that has the upgrade sway bar, maybe ask to compare the ride.
    2021 RT Limited
    2016 RTS , Pearl White
    Member nsuregal's Avatar
    Mar 2011
    Ozark, Mo
    I just had the sway bar put on my 2012 RT and it was a major difference. Handles so much better!
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Mazo EMS2 View Post
    exactly what my neighbor did. Rode mine, then said “wow, I’m getting this next”.
    HE>I
    2017 RT , Asphalt Grey
    Jul 2017
    Indiana
    Get the sway bar you will notice the difference.
    2015 RTs , Black
    Aug 2018
    Hobbs, New Mexico
    I put a Baja Rons on my 2018 RTL. Best investment I've made besides the bike itself. Noticible better handling immediately!
    Jul 2018
    Fountain Hills,AZ
    I just installed my sway bar about a month ago on my 2012 RT Limited..nite and day!! I would say waaayyy better handling and a lot less effort in turns = better safety..your not using as much effort on rides or trips therefore arriving more relaxed and not spent! Less jumpy too = safety! I highly recommend the swap!!
    Jul 2013
    Conn.
    Quote Originally Posted by RapidSpyder View Post
    I have a 2017, How was your ride improved? And did you install it yourself?
    2017 RTL , Grey
    Aug 2016
    Nashville, GA
    Default RT sway bars on a F3?
    I have been told to use a sway bar off of a RT on my F3 limited and it would help handling, is this a god way to improve handling on the F3, or order a sway bar? They tell me the RT sway bar is larger and stronger than the ones that come on F3's! Your response will be appreciated!
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by south GA Farm Boy View Post
    It is true that a Take-Off RT bar will give you a noticeable improvement in handling of an F3. An RT Bar will give you about 1/2 the improvement a BajaRon bar will afford.
    A Sway Bar is essentially a Spring. You can have 2 springs with the same diameter wire that are not only greatly different in strength. But also in their ability to retain their original tension over time and usage.
    People make the mistake of comparing only sway bar diameter to determine what kind of improvement they might get. But diameter is only 1 component of the equation. There are actually 3 separate things that go into the overall effect of any sway bar.
    1- Bar Diameter
    2- Steel Metalurgy
    3- Arm Length
    With a sway bar as short and small as the one on the Spyder. The overall effect can be changed a great deal by a very small change in any one of these parameters.
    Comparing diameter only is only valid if the other 2 components are identical. When comparing the BajaRon bars to OEM, this is not the case.
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Al_lockup View Post
    Had it installed at the Deadwood Rally. Also had it aligned by Squared Away. The biggest thing for me is on the interstate. I still get buffeted in the slipstream of large vehicles, but the Spyder tracks true. Also rides like it’s on rails in the corners.
    HE>I
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    I was a doubting Thomas for years on the infamous Baja Ron sway bar.. I had one installed on my new 2018 RT Limited and have seen a remarkable difference in handling on the curvy roads we all love to ride. I've been in the Black Hills of SD and just returned from the Ozarks and the sway bar make a lot of difference..
    BIG F
    Jul 2018
    Long Island NY
    Default Sway
    Netzley Tire installed my BajaRon stuff, they showed me my stock RT sway to compare to BajaRon’s. Big, noticeable difference in thickness. And Can Am uses plastic links (can’t figure out that decision), BajaRon’s Sway comes w much better links, not plastic.
    Netzley also did a Laser Alignment for me, that too made a difference. Next step for me is putting on car tires.
    ‘If you get the Shock Adjusters, you will immediately notice your front end is higher. And you know how sometimes the nose dives down when u hit the breaks? That’s gone w BajaRon’s Shock Adjusters.
    I had Netzley install everything, I prefer this type of product be installed by someone with experience, they’ve done a ton of them and I’m not a mechanic.
    Best of luck, I’m sure you’ll be happy.
    Aug 2009
    Cedar Park, TX
    Default I have a 2018 RTL sway bar
    If you want it you can have it. You would just need to get it shipped.
