Page 1 of 3 123 LastLast
Results 1 to 25 of 68
    May 2010
    Windber,Pennsylvania
    Default Undressed Ryker Photos
    Thought I'd post some pictures of an undressed Ryker that was on display at the dealer conference. You can see the belt cover pretty well in a couple of the photos, and how minimalist it really is. Very simple, very clever design
    May 2010
    Default more undressed
    more
    Quote Originally Posted by Triumphcycleman View Post
    Default Thanks .....
    Great shots...and there you have it...bare cbones...
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    It appears from these shots that the engine is installed longitudinally, is that correct?
    2018 RT LTD , Black
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    No belt = no belt cover! Driveshaft cover only.
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Default Naked Ryker
    Where does the gas tank go and where is the "gas cap" access?
    Happy owner of 2014 White RTS - SE6
    May 2010
    Default engine configuration
    Yes. The crank is aligned with the chassis, the CVT drive clutch runs straight off of it (see pictures from the rear) so there isn't much "loss", it goes thru the belt to the driven clutch pulley, which powers a very simple forward/reverse gear box. There is a lever on the left to select either F or R, and above, near your left knee, is a lever to lock it in "park". Of course the output shift of the gearbox turns the driveshaft to the rear differential. As for the 600 vs 900, it is simply a matter of 2 cylinders or 3.
    Quote Originally Posted by ottawa-rider View Post
    Bryant, Arkansas
    There is no belt, it is shaft driven
    Cruzr Joe
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Quote Originally Posted by Boilermaker View Post
    I think he meant the cover for the CVT belt he mentioned in another post about maintenance. The big black plastic bit in photo 3 that looks like it's off the back of a washing machine!!
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Sep 2015
    UK
    Does the lever have to be held in the reverse position is does it lock into reverse? I'm interested because I have a prosthetic left leg (full length) so couldn't operate it with my left foot, but I could reach it to move it into place with my hand I imagine.
    WOW! Nekkid Spyker!
    Hubba Hubba!
    Cruzr Joe
    Shaft driven... with a CVT transmission!
    (That IS belt-driven!)
    Aug 2008
    MA & NH
    Not even X rated.
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Cruzr Joe
    There is a belt from the drive clutch to the driven clutch (CVT Transmission). The driven clutch is connected to the gear case which drives the drive shaft to the rear wheel. See picture on this page: https://can-am.brp.com/on-road/exper...hnologies.html
    2020 RT Limited , Petrol Blue
    Sep 2015
    Muncie, Indiana
    Cruzr Joe
    Okay, okay! We get it! Cruzr Joe and I apologize for our possible misunderstanding. We don't know which cover the OP was talking about ,so I think we all know now that the CVT is belt-driven and the rear wheel is shaft-driven. Everybody can just move along now.
    May 2009
    Connecticut
    I'm hoping the Silver Grill (below Radiator) and 2 side grills near wheels will be add ons for the Normal Version because they really help the appearance No matter what color you choose. My dealer says I'm crazy to trade in the F3 BUT he got to the meeting Late and NEVER drove one?
    Sea Doo GTI-SE 90 Jet Ski!!
    Aug 2012
    CO
    Does that whole upper assembly pivot up/forwards on the production model? That would greatly enhance access to the engine bay.
    Wonder if some customizer will come up with a sleek swoopy racer (non-tractor) looking body panels, that would open up a whole new industry. More like their Sea Doo and Ski Doo lines.
    JLohPhotos
    2008 GS , Millennium Yellow
    You're not actually wrong...
    The final drive is by shaft
    The belt operated transmission is where things get a little bit "wonky"...
    Shaft drive, and belt transmission!
    (Are you missing a strap for one of the hard saddlebags?)
    May 2009
    Connecticut
    https://youtu.be/A1c7cU9NSeU
    I Know the Basics of CVT but this Video Gave me a Pretty good idea of what changing a belt would entail . I Love the Ryker concept More every day!
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by Spyderjuice View Post
    I've been looking at the pictures too trying to figure out where the gas tank is and where to fill it.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Nov 2015
    And what's with no lug nuts??? Do the wheels slide onto a splined axle and held on with a single nut and safety pin?
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Early information stated that there is only ONE saddlebag due to the shaft guard on the left side. We joked about it in an early thread--but I don't know if the issue was totally resolved.
    Johnson, Vermont
    Quote Originally Posted by SteveLaoyster View Post
    There is a cover under the handle bars that slides back toward the seat to expose the gas fill. There is no actual cap.
    Durham,Maine
    Looks like $10,000 to me!! May be fun to yank around the hood, but you get what you pay for!!
    2012 RTL , Pearl
    Sep 2018
    Texas
    Default Rear fender differences
    Just a thought......
    Am I the only one who noticed that the Rally model has only a small "splash" fender over the rear tire and the regular one has a full fender?
    Seems like the off road model would just make a mess of the underside with the shorter fender.
