Results 1 to 6 of 6
Hybrid View
    Active Member SpyderBen's Avatar
    Nov 2010
    Leesburg, FL (Central Florida)
    Default Damage to seat shock molding
    2010 Spyder RT
    I replaced the seat shock with a Stabilis SG350911 shock. When I opened the seat(a moment later) the attachment molding busted. Any suggestions other than replace the seat?
    what is the PSI of the BRP stock shock? The auto store(O’reily’s) wasn’t sure of the Stabalis.
    Default Not sure....
    If it broke off in a chunk you could try epoxying it back. Maybe a metal plate to re-inforce with pop rivits or screws.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    how about a twig with a rubber cup on each end, that you can use like a prop rod.
    ...just kidding. Corbin seats are so heavy, that they do use a drop down prop.
    Of course with the fuel door, it's not as critical because you're only under there occasionally.
    I imagine you will have to fabricate something. Good luck.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Sep 2016
    clark county indiana
    Default under the seat
    I guess you are saying the " shock mount that is at the seat location " and not the one that is on the frame , took a quick look at mine , and it looks like you can get a piece of aluminum angle , ( 1x1 x1/8 th thick ) make a couple of cuts in one of the angle legs , bend it too the seat contour ( there is a trough , or recess that runs front to back in the same location as the shock mount location ) when you get it bent as you like it , you can get it welded or maybe J-B weld epoxy , and you can either pop rivet too the seat ------- and while all of this is going on start looking for a nice replacement seat .... ( this angle fix will look pretty home made , and you would only want too put gas in it at night so no one will see )
    Dec 2015
    NE Ohio
    I feel for you OP.
    I have a comfort seat off my 2011 RT I'll part with if you need another seat.
    Dave
    Nov 2010
    Default Details plus photo, please. Thanks.
    Thanks for your thoughts.
    Quote Originally Posted by KosherKid View Post
    I feel for you OP.
    Dave
