Results 1 to 8 of 8
    Aug 2018
    Huntsville AL
    Default Orange Warning bar when adjusting ride
    I have an orange "warning" bar when I try and adjust the ride setting either in motion or when parked. Is that the air bag or the switches?
    Oct 2016
    Faribault, MN
    Likely the ACS Compressor / not the air bag or switch
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2014
    Cornish, Maine
    Default orange warning bar when adjusting ride
    Where is this warning bar on your screen? I have heard a weird fluttering sound when stopped or just starting sometimes. I think it is the compressor. Never heard it before.
    Aug 2018
    Huntsville AL
    Default Orange warning bar
    When the switch is used to adjust the air ride on my 2015RTL the graph bar left side that indicates the selected pressure turns orange and has the word warning in the middle going vertical.
    Oct 2016
    Faribault, MN
    spyDerred15, Does your horn and fog lights work? The fuse for all three is the same. If they work then it's likely the compressor has failed.
    Safe Rides,
    IBA 70020
    Oct 2016
    Faribault, MN
    Quote Originally Posted by Myron Ah View Post
    That is likely the compressor adjusting. Have you had a passenger on then off the bike between some of the times you hear this.
    Safe Rides,
    IBA 70020
    Active Member 11rtLTD's Avatar
    Mar 2017
    ICT
    When I would try to adjust manually with rocker switch on dash, I would get a bright orange "manual" notice... yup had to have the compressor replaced.... about $700.
    It's a 21 now....,BUT I like being on top
    TricLed afterburnerz gen2
    BajaRon sway bar
    F4 customs SRT 28" Clear Wide
    2011 RT limited , BajaRon plugs and custom wires Pearl white
    Sep 2012
    Stetson, Maine
    It could be your compressor or it could be your ACS switch. I have had to replace 2 of them..
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
