Results 1 to 9 of 9
    Active Member amkrat's Avatar
    Sep 2011
    Gretna, Nebraska
    Default Temperature sensitive SE6
    Just returned from a great ride through New Mexico. Woke up on Thursday morning in Chama with temperature of 40 degrees. Transmission would not shift into reverse, neutral or downshift at all. It did upshift just fine however. Thankfully I was parked on a level parking lot at the motel and I could push it away from the stall. After it warmed up later, it began to act normally again. I say normally, but I have been having trouble downshifting. Having to push very hard on the (-) paddle shifter to do anything. My dealer has ordered a new assembly but they are not available until October. The next morning it was more of the same. 37 degrees and no luck with the (-) side of the paddle. Finally after the temps warmed up into the 50's, did downshifting start to work again. Nebraska mornings in the Fall can be 40 degrees pretty easily. I hope this isn't going to be a problem
    Jun 2010
    Las Vegas
    Is that a 17 or 18? I have read of a few people having shifting problems on 18 RT SE.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2011
    Gretna, Nebraska
    It is an 18 RT Limited. Downshifting, reverse, and neutral has been an issue ever since I rode through a heavy rain a month or so ago. Thankfully it is under warranty. That left handlebar switch group is over $400 bucks I'm told.
    Jun 2010
    Las Vegas
    Looks like it us a known issue. See this thread for more info. http://www.spyderlovers.com/forums/s...AUAL-DOWNSHIFT
    2010 RT- 622
    As unlikely as it may be: check your oil level.
    Sep 2011
    Gretna, Nebraska
    ??????????? I will tho I don't see the connection yet. I wish I could go out and check it. Having to ride miles, the let it sit and idle for 10 minutes seems like overkill.
    Jul 2014
    Mint Hill, NC
    Just get it to the dealer and let them fix it under warranty.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2011
    Gretna, Nebraska
    Yep, thats where it is going.
    Nov 2012
    Pueblo Colorado
    Default Like Ann Says - a known warranty issue the last couple of years...
    Quote Originally Posted by SpyderAnn01 View Post
    The left switch cluster probably is going bad---
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
