Results 1 to 17 of 17
    Nov 2018
    Altamonte Springs, Fl
    Default Spyder RT Seat Change to Backrest
    This is my first post. Just purchased a 2011 RT Roadster with radio and convienience package. The seat has no backrest or hole for one. Someone is selling a 2014 seat with everything on it. Will it fit my 2011? Photo is of my 2011 seat.
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Yes it'll fit
    2018 RT Anniversary , Brake pedal extended
    Mar 2013
    Yes - 2010 through 2018 ( most likely 2019 also) will interchange with each other. I had used a 2010 seat that I had sent to Russell Day Long on our 2014 RT.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I dg110270
    The company Utopia USA makes a file for your 2011, they even show on their website how to install it, you do not have to change all your seat.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Nov 2018
    Thank you.
    Apr 2017
    North Central Florida
    I have an (almost) brand new seat from a '17 RTL that has the backrest port that I will sell for a reasonable low price.
    And I will deliver it to you if your location shown in your profile is right.
    It does NOT have the backrest with it.
    Nov 2018
    I'll keep you in mind. Thanks
    May 2012
    North Las Vegas
    I Have a Russell Day Long that for an RT, that I will be selling. I am switching over to an F-3. I have the backrest, the seat is heated. I will have to be rebuilt and recovered, I am only 5'3" and I have it covered to reflect my military career. I paid well over $1800.00 for this seat, and will buy another for my new F-3.
    Here is Russel Day Long website that has prices. I will accept any reasonable offer.
    https://day-long.com/place-your-order/prices/
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Aug 2012
    Central Coast, CA
    PM sent
    2020 RTL SE6
    and on your new
    Linda has exactly that model. Utopia was an answer for a backrest...but you had to cut a hole in the seat. I believe the 2014's started coming with a backrest hole with insert plug. I put a Utopia on that one but have since replaced the seat with a BRP Comfort one. That one offered enough support for me that a back rest was no longer needed.
    Nov 2018
    I found a seat with backrest off a 2014 RT.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FlyBoy2121 View Post
    The company Utopia USA makes a file for your 2011, they even show on their website how to install it, you do not have to change all your seat. FlyBoy2121
    Unless you are getting the seat / backrest at a very good price, or you don't care how much you spend, you're better off going with a Utopia backrest. You will have to cut a small hole in your seat but it's no big deal and their instructions are very good. So is their backrest; I have one on each of my RTs.
    http://www.utpr.com/spyderrt.html
    The other thing I like about Utopia backrests is they can't easily be removed by a thief, which is not the case with Can-Am backrests I believe.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by dg110270 View Post
    I understand the 2014 and newer seats are slightly different from the 2013 and older ones. Can't swear to it, but Utopia does sell a different mounting kit for the 2014 and newer vs older seats. http://www.utpr.com/spyderrt.html
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    and on your new
    Was that hole and plug the only difference with 2014 and newer? I may be wrong, but there may be other differences as well because Utopia sells a different mounting system for 2013 and earlier.
    2014 RTL Platinum
    The newer ( 14+ ) seat pans ( this is what the foam and vinyl attach to ) Have four nuts/ferrules embedded in the pan - this is for the newer style bracket to attach to...………….Mike
    Dec 2015
    Oakley Utah
    Thanks, Mike. I thought it might be something like that.
    2014 RTL Platinum
