Results 1 to 11 of 11
    Member Airborne Engineer's Avatar
    Sep 2018
    Udall, KS
    Default Noisy shifting 2017 RT-S
    I have a new 2017 RT-S. Only couple hundred miles on it so far. My shifting seems pretty loud. I have read this is normal sound for a "solid well built transmission" but I believe this was from Can Am. Is there a break in period where it will drop after a while, or is this really normal for the Spyders? Thanks in advance for info.
    Robert
    SoFlo
    Quote Originally Posted by Airborne Engineer View Post
    Robert
    Not saying it is normal or abnormal, simply new. On our 14 RTS it had kind of a notchy, clunky not even smooth shifting gearbox during break in miles. Upon reaching the required break in mileage I swapped from BRP oil to Mobil 1 10-40 Sportbike oil and have had smooth wonderful shifting ever since. New oil filter and oil each 5000 miles.
    I did do an oil and filter change using BRP oil about half way through the break in miles as the shifting to me was that bad. This did help, but was short lived until switching to Mobil 1.
    Default NOISY
    …. I have a 2014 RT - SE ….. 41,000+ miles ….. Unless I wait for about 3-4 min. after start-up ( w a cold trans. ) it clunks either in reverse or forward gear...… but after that it's quiet..... It will get better as said above …… Mike
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    "shifting".... is a very vague description.
    That being said, the shift from neutral into either FIRST or REVERSE
    are surprisingly loud, almost Harley-esque.
    Gear changes shouldn't be noisy. Neither of mine shifted gears loudly
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default Compared to what ?
    Shifting seems loud compared to what - a previous Spyder you have owned / ridden or what you think it should be?
    Has anyone else assessed the loudness - another Spyder rider ?
    When the Spyder was new to me a few things seemed different from my Yamaha - but now that I am used to it the Spyder is the new normal.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Sep 2018
    Udall, KS
    Default Shifting vague
    Quote Originally Posted by 4 MARIE View Post
    I put it that way because I was referring to all shifting. Just seemed clunky. Especially if your accelerating quickly where you are not shifting at lower RPM's. Like merging onto a highway. Pretty similar to how it sounds after warmed up when shifting into the 1st or reverse. Might be just that I am not used to it coming for the 2 wheel world.
    SoFlo
    A consideration, and this is important and does cause some issues for some riders coming to the Spyder SE gearbox. Do not close or even slightly back off the throttle. I know folks say they do not but when they focus on a steady or slightly increasing throttle, the gearbox does fine and there is no drop / lag in the feel of the bike.
    Sep 2018
    Udall, KS
    Default No let off
    I admit I still do this sometimes, old 2 wheel habit. But I am trying to be conscientious about it. I don't know if that is what is causing my shifting noise or not. It doesn't cause any issues, there are no delays in engaging of the next gear or anything like that. Just seems noisy or clunky.
    Thanks for the replies. I will she what happens when I do the oil change and see if it helps.
    May 2018
    millsboro,delaware
    My 17 rtl is very clunky when cold from N to R or 1st,better when warm.When warm it can be clunky on upshifts,worse when you are pushing it a little.If you granny shift it at about 3000 rpm its not bad at all.Also when slowing down it can be clunky and kinda weird.Ive gotten use to it but I try to work the throttle so it isn't quite so bad.Im due for my 1st oil change so Im hoping a new type of oil may help.
    : 2017 RTL ORBITAL BLUE
    My observation is the harder the acceleration, the clunkier the shift. Gentle acceleration and quick tap on the paddle and it can be smooth as silk. Full throttle and quick shifts from gear to gear and it "...sounds like something wants to break!"
    Mar 2016
    Palm Harbor, FL
    I’ll bet this proceedure is in the service manual but I could be wrong.
    Go to the dealer and have them do the CIP (Clutch Initialization Proceedure) or maybe someone here (Lamonster maybe) knows the button push proceedure and you can do it at home. I do know this proceedure must be done on a hot clutch, transmission unit.
    We Honda Goldwing, African safari and CBX with DCT riders all have learned how to pro form this proceedure.
