Results 1 to 25 of 34
    Oct 2017
    Kent, Ohio, USA
    Default Arm Rests for RT
    Seeking recommendations for a stable, secure arm rest system for the RT. Last weekend I saw two items on bikes at SpyderQuest, (Lake George, NY). Both were insubstantial. One 'tucked away' to a position certain to catch the wind when not being used by the passenger. The other was flimsy and the slightest weight on the 'arm' caused it to wobble and flex.
    Any suggestions for a retrofit to help a passenger feel stable and comfortable during a multi-hour ride?
    Caven
    Caven Mcloughlin; caven@kent.edu
    Active Member whiteyron's Avatar
    Oct 2013
    Eden Prairie, MN
    Default Arm rest for the RT
    I had a set of the Rivco arm rests, after trading for a new 2018 RT Limited, I installed the BRP arm rests, my wife loves them, she said they are very comfortable.
    Invalid Emails
    Apr 2018
    Watertown south Dakota
    IMG_0373.JPGRivco products works great for us
    2018 F3 Limited , Intense Red
    Sep 2016
    clark county indiana
    Default arms rest
    too much , not adjustable ? a pain for the passenger to get on and off ...
    these swing out and are some what comfortable , the passenger can get off and on easier ! but the do get loose over a few miles of riding , almost need to have a star washer or compression washer in between the swing point ... -------> pretty easy to install I had one on my last cycle ...
    https://youtu.be/7Vibe8ac4vE <-------- this is one shawn smok is putting on an 2018 model , I like the way they flip up and out of the way and look appealing ... ( uhhhh shawn is in comfort Friday attire )
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I got my wife the BRP ones, she loves them. They are the only ones that swing up, not out, and she feels a lot safer with them.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Throw another vote on the pile for the BRP armrests!
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    The BRP arm rests shown in the attached video are nice, but do not stay in the flipped-up position when riding. They are only made to flip up so the passenger can mount and dismount more easily. I have them and know this to be true! I suppose that if this was a major issue, you could add a friction washer or some other mechanism to hold them up when riding.
    https://youtu.be/7Vibe8ac4vE <-------- this is one shawn smok is putting on an 2018 model , I like the way they flip up and out of the way and look appealing ... ( uhhhh shawn is in comfort Friday attire )[/QUOTE]
    Faribault, MN
    Quote Originally Posted by Caven View Post
    Caven
    As others have said, Get the BRP RT Armrests. Mine do stay up when the passenger isn't on. The pivot bolt could be tightened when installed. My wife has now enjoyed thousands of miles with them and has convinced a few others of how solid they are. I weigh 260+ and can put my wight on them and they don't flex.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Faribault, MN
    Quote Originally Posted by Boilermaker View Post
    [/QUOTE]
    boilermaker, Mine have always stayed in the up position when not in use by my wife, though you'd have to almost fully uninstall them now to correct it, I checked that the pivot bolt was tight enough for me before installing and I've used them for months now, over 8k miles since installed and they stay up all of my Iron Butt rides, even VERY bumpy dirt roads going into the Northwest Angle of MN.
    Safe Rides,
    IBA 70020
    Jul 2016
    Kamloops B.C.
    I second the fact that mine stay up.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Sep 2015
    Muncie, Indiana
    boilermaker, Mine have always stayed in the up position when not in use by my wife, though you'd have to almost fully uninstall them now to correct it, I checked that the pivot bolt was tight enough for me before installing and I've used them for months now, over 8k miles since installed and they stay up all of my Iron Butt rides, even VERY bumpy dirt roads going into the Northwest Angle of MN.[/QUOTE]
    Thanks for the info. I figured as much. I am not going to worry about it since it requires disassembly to correct.
    Jun 2018
    Louisville, Ky
    I've been researching arm rests as well and here is a set that swings out and is adjustable in height. They are longer than other arm rests and are attached to a bracket that bolts on to existing bolts under the seat. It comes in Black, Chrome and a Spyder Web version. The vendor is https://www.facebook.com/DiamondRAccessories/. Their website is currently under construction. They will be at Maggie Valley in Oct. I can't find the prices I had but know the armrests are under $300.
    Aug 2018
    Hobbs, New Mexico
    I just finished putting a pair of the BRPs on my 2018 RT and the girlfriend likes them and they look like they belong on the bike.
    Active Member 3 Wheel Rider's Avatar
    Jan 2015
    San Antonio, Texas
    Another vote for the BRP armrest!!!
    2014 Spyder RT Limited SE6
    BRP Tri Axis Adjustable Handlebars
    BRP Adjustable Wind Deflectors
    BRP RT Passenger Armrest
    BRP Driver's Backrest
    BRP Travel Cover
    Baja Ron Swaybar
    SpyderPops KOTTS
    SpyderPops Bump Skid
    Lamonster NVB Highway Brackets w/ Gripper Pegs
    Lamonster LED Headlights & Fog Lights
    Custom Dynamics HMT Brake Light
    Show Chrome 7.5 inch Spiral Antenna
    SpyderFlap Mud Guard
    Helmetlok w/ T-Bar Extension
    Hopnel 5PC Luggage Set
    Airhawk R Seat Cushion
    Rivco Dual Flag Mount
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by vienna7475 View Post
    Last I heard, these were not available anymore. I wanted some for my last RTS and they were not available then. Hopefully, they will bring them back. I guess you'll find out at Maggie Valley.
    I had the Diamnod-R passenger armrests on my 2010 RT. They were (by Far!!); the best of the swing-out types!
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by bcer960 View Post
    Ray
    Too easy!
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by wilpir View Post
    Too easy!
    No pills required........
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Linden, CA
    Default Rivco and Big Bike
    I have the Rivco & Big Bike units they are hi qualityl well made HOWEVER....
    they swing out NOT UP, the only armrests that swing up WERE made by ISCI
    and only for the GS-RS-RSS-ST. so the 2 above are the only ones out there
    I have seen people modify them to lock in place.
    Call me if yo want more info
    209-887-3283
    Email motorcycledave@mac.com
    Ride Safe
    Dave
    Caven
    Active Member meerkat's Avatar
    Jul 2015
    leesburg florida
    Default RT arm rests
    Take a look at the Corbin . I have them on my 2018 , which came off my 2017 . They are well paded and have a cup holder intergrated . I like them . Meerkat
    Durham,Maine
    Cobins work great on mine!! Wife loves them
    2012 RTL , Pearl
    Danbury Connecticut
    OK, OK, I'm convinced.
    BRP armrests it is.......................
    What's the best place to get the best price ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Dec 2016
    Oneonta, NY
    Default To WAYNE WARNER
    I have a set of Diamond R Armrest that i will sell for 125.00 they have the cup holder and a pocket for a cell phone on them . They came of a 2014 R T L. Just like new. If interested call me @ 1 607 4323069 Donald Harvey Oneonta New York
    Jul 2016
    Kamloops B.C.
    Depends on your relationship with your dealer, mine gave me 20% off the list.....
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Oct 2017
    Kent, Ohio, USA
    Default Thanks for selling me these armrests
    Quote Originally Posted by donsspyder View Post
    ... Don, Great talking to you, and congratulations on getting two bikes into your family. My money to you is on its way.
    Caven
