Results 1 to 15 of 15
Hybrid View
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    Default RT-622 Trailer Hub, Bearings, Races
    I got a 2011 RT-622 from 2nd owner with supposedly low mileage and installed ground kit, new harness and PM on the wheels. I read just about every post on here (and all over youtube) about bearings and races. One side looks fine but the second side looks like some water got in and is at least questionable to me. I'd like the opinion of those really knowledgeable on this subject...
    The race while discolored is completely smooth to the touch all around - there are no obvious scrapes or gouges. The bearing is discolored on the casing, the rollers seem to be in good shape (no flat spots or anything) except for slight discoloration on some rollers. I know the general rule seems to be any discoloration or anything = replace and replace bearings and races together.
    Unlike a larger boat trailer hub where you can use a screwdriver/chisel to get on the lip and hammer out, there doesn't seem to be a way to grab these races to pull out. Maybe a specialized race puller tool but still seems like nowhere to grab it.
    I took it to a trailer shop and he said he can't take them out, and even if he could it would cost $20-$30 and he sells/swaps hubs for $35 (I guess on boats they do that often - just swap out refurb hubs). I had him take a look at it and he actually thought they looked fine and said he would have no concern regreasing and using as is. He said unless it was gouged and looked torn up he would not replace race/hub and bearing seemed to spin fine.
    Maybe I am overanalyzing but I don't want to be the guy on the side of the road with a torn up wheel from a frozen bearing. Of course I want to do the most cost effective/easiest thing but SAFELY.
    I see my choices as:
    1. Bite the bullet and just replace hub assembly to get new hub/races/bearings and not worry about it.
    2. Just replace the bearing (most recommend replace both bearing and race but trailer shop said you can replace just bearing)
    3. Continue to look for a way to replace the race in existing hub and get new bearing (almost sounds like as costly as 1 at least in time/effort)
    4. Repack it all, grease well and just re-install and quit worrying since there is no obvious major damage and this is only a 400lb max vehicle not getting dunked in water all the time.
    And I also intend to install bearing buddies when re-assembled...
    I'm leaning toward either 4 or 1 but obviously don't want to get a new hub if I don't really need to.
    Those that really know this stuff please reply with your choice... Thanks...
    20180909_183922.jpg20180911_165008.jpg20180911_184426.jpg20180911_184423.jpg20180911_184412.jpg
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    SoFlo
    Get 4 new bearing cups, both hubs, stuff it all in a box and leave it at my front door. Give me a couple days and you can come get it with cups replaced.
    Not doing it while you wait or watch. Simply busy and it gets done at some point.
    Mar 2015
    Brockport, NY
    Default You can’t beat this offer.
    Man, what an offer!
    2014 RT-S Pearl White
    Dec 2015
    South Florida
    Yes, thank you so much for that amazingly generous offer. I will be in touch...
    Funny thing is there seem to be 2 brands of bearings in it - both L44649, on each wheel the outboard one has a black finish on the perimeter and says I think HCH while the inboard ones there is no black (more like a cast metal rough finish like in picture) and no other markings other than #. Just thought that was interesting.
    OLD/TRADED
    Sep 2014
    USA
    Get a flat chisel and a good angle and pound out that race. I did it on my hubs.
    How are the axles? I found mine at the seal area were starting to rust which would cause seal failures.
    Heres a link for new bearings etc.
    https://www.ebay.com/itm/K1-150-2-00...l/111709525286
    Those hubs are not standard (BRP) unless he is able to get them??
    I Ended up getting hubs from BRP but never used the one I bought.
    Then I put bearing Buddys on mine and took a trip. I still havnet checked to see how well the grease got into the rear bearing yet.
    Dec 2015
    South Florida
    My first plan was to pound them out but I could not see any way to do so. The race seems like it is almost recessed in from the center of the hub, I could not seem to get on the edge of it through the hub even with a very thin edge. Seemed like maybe from the same side with a hammer puller but wasn't going to buy one of those to try. The hubs should be original BRP. I ordered the Timken SET4 kits (Bearing and race) from Amazon.
    Axle was discolored in one spot and I cleaned it up with SS wire brush per PMKs suggestion.
    OLD/TRADED
    Sep 2014
    USA
    The bearing races come out. There is a very small edge that can be pounded out with a chisel. I have done it already. Just keep working your way around.
    I put my hub on top of wood and a solid table then pounded the race out with a flat chisel. It does take a bit of effort and Patience but they do come out.
    Or find another trailer place that knows how to get bearing races out. Or your BRP dealer? or take up PMK's offer
    I highlighted the areas that need to be pounded out work your way around .
