Transmission Problems maiden voyage 2018 RT LTD
Was on my maiden voyage 2018 RT LTD , cruising along in 6th gear then all of a sudden sounds like the transmission exploded. Banging and clanking, marbles in a blender, burnt clutch smell. Pulled over immediately. Let it cool, won’t go into reverse, goes into first after a few tries, but bangs and clanks like the gears are butting heads. Only 40 miles on it. Taking it back to dealer but that’s another 3 1/2 hr drive one way. Anyone have any ideas what happened? Would like an idea of what may be going on when I talk to dealer on Tuesday. Oil level is fine, no fault codes.
Yeah, something very serious.
Sounds like a replacement bike is in order. I wouldn't even mess with trying to get it fixed. Let your dealer and BRP sort it out as you ride away on your new replacement bike.....
Semper Fi
I doubt that but a new transmission is possibly what's needed.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Very sorry to hear this. Have patience, BRP can take a LONG time to resolve large warranty claims....months. But they usually do the right thing in the end. You really should see if your dealer will swap it out for another new one and then fix it on their own time since its so new. Good luck and keep us posted.
Getting a new replacement
I spoke to the GM at our dealership. They are going to give me a new unit and let BRP fix this one. We have purchased several things from them, including another Spyder RT just a couple weeks ago. So they are taking care of us.
Yikes...!!!
Sorry to hear. From the discription of the sounds I'm surprised it goes in a n't gear. but then the burnt clutch smell could explain a lot and the gears could be fine. Will be interesting to find out but not fun for a first ryde...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
brother , or sister !
get your bike history in order for b-r-p if this clutch came apart this fast , they will want to know your break in history , did you do all the sequence ride instructions ? ( any one who bought a new cycle please chime in ) what is the " break -in " ride suppose to be , and how many miles until someone can let-er rip down the road ? ( I had been thinking the break in period was like 1000 miles under 50 m-p-h ? with starting and stopping , to go through the gears ? ) ------- Saxmanvtx wow sorry for your interrupted ride , but tow that baby back too the dealer , and start from the beginning ! keep the forum up too date please this is an interesting thread ... ( as akspyderman says )
Ideally, your dealer of choice has an excellent service department with quality technicians. From past topics about early / low mileage failures, it seems the dealer is a huge factor in the outcome and customer satisfaction. There are far more topics regarding the Spyder being repaired and the customer getting some additional warranty time added on. Unless it is extremely bad, with irreparable damage the likelihood of them replacing the entire Spyder is very low.
The way you described it, if the gearbox has failed, BRP will make the decision on how they will proceed. Expect, if the damage is bad for the bike to be down for several weeks or more, so pressure your dealer for a loaner to ride while yours is repaired.
Tags for this Thread
