2012 spyder died
Ok took about 25 mile ride
on the way home in traffic she died cut off on me a few times then dead nothing at all
called a buddy for a trailer pick up and about 1hr later she regained power,,,,,,, but would not start
Pushed her up on the trailer brought her home now she starts like nothing ever happen
Anybody have an idea????
I think its the battery
Any codes? I would start by checking to make sure each battery terminal is clean and tight. Then perform a volt and load test. If battery is weak or has a dead cell it will show.
No codes at all!
That what scared me
Curious...🤔
My 2012 RS Sm5 battery just died which makes it one of the long lasting ones. But if yours is still the original I would suspect the problem is there. So normally you need to check all battery connection and ground connections. Check that all fuses and relays are well seated and good. A good load test on the battery will be good. Try jumping it with a car (engine not running) and see if it starts up.
I had this too.
I agree with all this. Sounds like the battery and or connections. MY '14 RT would
be cruising right along then just die, at speed. Coast to the side of the road and it
would take a few minutes but then start. I got no codes. I had it to the dealer twice.
They dug a little deeper and found a ground cable corroded. Problem solved.
If your battery is the original I'd say you got your money's worth.
Chuck
watching
watching the thread , let us know what the results are !
