Results 1 to 4 of 4
    Mar 2015
    Philadelphia, PA
    Default GS Rear Shock Replacement
    2008 GS with 18k miles
    looking to replace/upgrade my rear shock. My current one have a lot of rust on it. should I get the RSS or is it the same? Mainly looking for a used one
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I'm extremely happy with my ELKA rear shock. It was set up by the factory for my weight & riding style. Not cheap but worth it IMO.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Default Sure....
    If you find any of the GS, RS, RSS, ST rear shock they should work fine. Just need to set up the adjustment to suit your ryde. If you go for new there are quite a few out there but as you will see quite pricy in some cases.... the oem new from Cheapcycleparts.com are $99.00
    ​2012 RS sm5
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi 267,
    Re: looking to replace/upgrade my rear shock.
    You might consider reading the thread titled: Rear Shock Mod (spring change out)
    in the: GS/RS ShopTalk forum.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
