Results 1 to 10 of 10
    Dec 2015
    Alvord,Texas
    Default Unknown connector
    I have a 2012 RSS SE5 that has this connector that I've never noticed before,it's located at left upper control arm and if you look down the hole it has 2 female spade connectors that have dielectric grease on them....it appears to have never been plugged in so im assuming I dont need it but wanted to know if any one knew what its for....
    Thanks in advance.
    Jul 2011
    Mitchell, Ontario, Canada
    That is for the optional 12V accessory plug in the Front trunk. It appears you don't have that option but they are all wired for it.
    Dec 2015
    Alvord,Texas
    Thank you billybovine....I'll wire tie it up out of the way.Nice to know i have an aux power source if i need it.
    Active Member Gonzo5776's Avatar
    Aug 2018
    Woodbridge VA
    Quote Originally Posted by sulaco View Post
    Thanks in advance.
    Looks like we have the same Spyder.
    2012 Can Am spyder RSS
    Weekend rider
    Dec 2015
    Alvord,Texas
    Quote Originally Posted by Gonzo5776 View Post
    Yes Sir....Yours 2012?
    Default Good to know....
    From the replies to your inquiry it is good to know.... I have a 2012 RS and it does not have one of those....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2011
    Yes it does.
    Aug 2018
    Woodbridge VA
    Yes its a 2012 and I don't think mine comes with that connector. Will check not 100% sure.
    Weekend rider
    Dec 2015
    Alvord,Texas
    Thanks....I'm blind in one eye and cant see out the other(2012 right next to your Spyder picture)
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi sulaco,
    Re: Nice to know i have an aux power source if i need it.
    I am currently using that power source for some front lights that I added to my '08.
    FYI, it powers up when the ignition key comes on & powers down about 10-15 seconds after the ignition key is turned off.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
