Unknown connector
I have a 2012 RSS SE5 that has this connector that I've never noticed before,it's located at left upper control arm and if you look down the hole it has 2 female spade connectors that have dielectric grease on them....it appears to have never been plugged in so im assuming I dont need it but wanted to know if any one knew what its for....
Thanks in advance.
That is for the optional 12V accessory plug in the Front trunk. It appears you don't have that option but they are all wired for it.
2018 F3 LIMITED
Thank you billybovine....I'll wire tie it up out of the way.Nice to know i have an aux power source if i need it.
Thanks in advance.
Looks like we have the same Spyder.
2012 Can Am spyder RSS
Weekend rider.
Good to know....
From the replies to your inquiry it is good to know.... I have a 2012 RS and it does not have one of those....
2012 RS sm5
Yes it does.
2018 F3 LIMITED
Yes Sir....Yours 2012?
Yes its a 2012 and I don't think mine comes with that connector. Will check not 100% sure.
Weekend rider.
Thanks....I'm blind in one eye and cant see out the other(2012 right next to your Spyder picture)
Hi sulaco,
Re: Nice to know i have an aux power source if i need it.
I am currently using that power source for some front lights that I added to my '08.
FYI, it powers up when the ignition key comes on & powers down about 10-15 seconds after the ignition key is turned off.
Jerry Baumchen
'I'll never forget what's her name.'
'Things are more like they are now than they ever have been before.' Dwight Eisenhower
2008 GS SE-5
