Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Exclamation *UPDATE* Brand new Soft code P1F05 DPS, then P1F00
    Update* New Video
    https://youtu.be/yFq2PE9E-8Q
    Im new here and need some help!
    Out of the box code brand new ---- P1F05 then the DPS is in-op. Turn off ign wait for timer tooturn off then its okay to go, only really does it at first start then I can ride all day with no problem. Battery is good, I cleaned all terminals and frame ground behind left front tire.
    I have not tried checking plugs on DPS and I can feel a little pulse when moving handle bars at times stationary at idle.
    BRP care said to take it to a dealership........
    Bought out of state new so now It needs to go to dealership in western PA and my choices are Mosities or Can am of Windber (50 miles)
    2018 CAN AM SPYDER RT LIMITED DARK 500 miles first code was @ 20 miles
    *This code googled only came up with an ATV from years ago?
    Love the dam thing coming from a Goldwing my legs are happy.
    Thanks for any help you can share!
    2018 RT-L , Blue
    Jul 2014
    Mint Hill, NC
    Brand new? Get it back to the dealer; the problem is on their warranty nickel.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Nov 2015
    Chardon, OH
    Can Am of Windber. Consider having it laser aligned while you’re there, also.
    Doug
    ”Freedom is not a loophole”
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Snowbelt Spyder View Post
    Thanks doug, how much is this "laser alignment" going for anyways?
    I've heard a lot of good things about Windber dealership too.
    Thanks,
    Patrick
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    I agree, But prefer to do what I can BEFORE I have to go there!
    Thanks,
    Patrick
    2018 RT-L , Blue
    Nov 2015
    Chardon, OH
    Quote Originally Posted by bluewoo View Post
    Thanks,
    Patrick
    Patrick, usually in the 100 to 120 range. They should be in that ballpark. Ask for Tim.
    http://www.spydercomfort.com/index.html
    http://www.spydercomfort.com/dealerspa.htm
    Doug
    Sep 2018
    greensburg,pa
    Thanks, I was able to find a PDF file for a ATV and the code is this (P1F05 DPSMotor currentsensorrange/performanceMotor input vs output Currentcorrelation check failedExternal troubleshootingis not possibleReplace the DPS.)
    Im so sad right now, you think a lose wire or bad battery could cause this?
    My voltage is 13 off and 14.5 running at idle?
    Frustrating,
    Patrick
    2018 RT-L , Blue
    Default Relax.....
    Other vehicles codes may not apply. I have not seen a DPS go out lately or this soon on any spyder. What I have seen is the yawl and angle senors being off and causing DPS issues. The best is to get to anyone that has the BUDS system and checking the settings. All good alignment locations should have BUDS as they have to reset these sensors after alignment....
    ​2012 RS sm5
    Nov 2015
    Chardon, OH
    Default Yeah, frustrating.
    Can’t find the code on any existing Spyder related code lists that I have or in the App. Word is that the DPS design was changed in 2017. On those ATV forums, the answer was always a DPS replacement. So, the good news is that you’re under warranty and that maybe they can get you in soon. Could be that they just need to hook you up to BUDS and do some sensor resets. Could have been a dealer prep issue. Stop in at the Flight 93 Memorial while you’re in the neighborhood. Put the trip to another good use.
    Doug
    Oct 2014
    Western Pa South Greensburg
    Default Plugger2
    [Canam of Windber is the best in this area.. Almost everybody in our club goes to him.
    Thanks for any help you can share![/QUOTE]
    Sep 2018
    greensburg,pa
    Was going there ever since it was a chain linked fence, But once the memorial was built it's a little too busy now and noisy. I was working at Pep boys in greensburg that day.
    Prey that never happens again........
    South Greensburg - were neighbors!
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    Just an update: Talked to Tim @ Windber Can am dealer and have to drop it off. Tim sounds like a great guy and is pretty sure the DPS is most likely faulty, But he has to plug it in and run some test. Cant get to it until 18th! Something going on in Pittsburgh for most of the week so they'll be all be there and not his dealership.
    Patrick
    2018 RT-L , Blue
    Jun 2010
    Las Vegas
    I have a 17 F3T which has the new “brushless dps” on our last trip I had check engine light and DPS errors come up. It happened twice and both times my DPS was not working. Both times the errors cleared after restarting and the dps went back to working. It didn’t cone up again on the next 3500 miles so I’m going to call it a fluke.
    Also, BRP has many new codes on the late 17 & 18 models that were not previously used.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2018
    greensburg,pa
    DPS is very ruff/pulsating before it fails. Once I do a restart its okay but still pulsates with the idle of engine. Turn off engine and DPS is smooth until system times out.
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    Ok, Im a mad scientist when it comes to trouble shooting!
    I read about an ATV having a similar problem and a new battery cured it so I put a car charger on the battery (10ah) and I started the spyder and I could not get the DPS to fault so maybe the battery has been in it for awhile at dealer (dust proves it was not a fresh prep) and has sulfated?
    12.6v over night and I cannot tell how low it gets when starting but seems slower than normal to me cranking.
    Repeat again in the AM before I take it to Windber Can AM.
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    Ok ,left on tender all night and no problem with DPS today so I will call Tim and get any suggestions he can offer and its raining again.
    Pretty sure its a weak battery that was never charged this year after assembled at dealer and sulfured up the battery.
    2018 RT-L , Blue
    Nov 2012
    North Las Vegas, NV
    It's a good idea to keep it on the tender when you aren't riding it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2011
    Mitchell, Ontario, Canada
    P1F05
    Module: DPS
    Description: Motor current sensor range/performance
    Possible Causes: Possible internal component failure
    Service Actions:
    If Occured: - Check the connectors on the DPS for moisture and corrosion. - Clear the Fault.
    If Active: - Key-Off until complete vehicle shut-down. -Key-On- If fault is still active, further external troubleshooting is not possible. DPS must be replaced.
    2018 F3 LIMITED
    Sep 2018
    greensburg,pa
    P1F05
    Module: DPS
    Service Actions:
    So sad it's brand new! Seeing Tim @ Windber Pa Can Am Tuesday and Florence will make it interesting for sure!
    Big thanks billybovine!!!!!
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    Update: They did find a hard code P1f05, But being unable to duplicate it can am will require another trip to the dealer when it does this again.
    Will wait and see.
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    And today code P1F00 came on right around a turn and I lost the DPS again then crossed the double yellow and if a car was coming?
    Making some phone calls tomorrow
    P1F00
    P1F05 were in the memory at Windber Can AM but they could not duplicate sent me home, I almost had an accident today, this needs addressed!
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    It now is at Windber Can Am.
    Steering went out twice getting there, you would think this is a safety issue and the dam thing should of been tagged out before someone get seriously hurt.
    700 miles - didnt make it to 1000!
    2018 RT-L , Blue
    Aug 2018
    Vancouver, WA
    It's time to file a NHTSA complaint.
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    Sep 2018
    greensburg,pa
    Quote Originally Posted by IgoFar2 View Post
    Your Complaint Number: 11132980
    Thanks for the link!
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    *Update*
    Rode it home 50 Miles (3 down pours ) from windber and the steering is night and day vs before! No pulsation and so far no codes !!
    Thanks for all the help from the Forum Members, Tim @ Windber Can AM and BRP -> They really stepped up on this situation.
    I wish it wouldnt rain everytime I take a long ride anyone know where I can go? LOL
    Patrick
    2018 RT-L , Blue
Tags for this Thread
