As stated, these wheels are not chrome; instead the finish is bright aluminum.
And, since the tires are shown as 15", it is safe to assume the rims are 15" as well.
Thanks for looking.
Pete Tamblyn
Cleveland, GA
2020 F3 Limited (black)
Time Out XL1800 cargo trailer
2019 Royal Enfield 650 Interceptor
2018 Kawasaki Versys-X 300
2013 ST (sold)
2015 F3-S SOLD
2014 RT-Limited (cognac) SOLD
Hi, I'm interested in knowing more about your wheels. Are the tires off of a Spyder or are they motorcycle tires? Did the wheels come off of an RT? I have a 2016 RTs. And where exactly in n. Georgia? We're in Louisville, KY.
The wheels and tires came directly off another forum member's trike. The spoke pattern appears to be that of an RT (someone feel free to correct if I'm mistaken).
The tires are OEM Kenda.
As stated in my signature line, the items are in Alto,GA (30510)
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
I am wondering if B R P. Is using a metric hole pattern ? And the ones you have are English ( or standard pattern ). Being out side of the measurements to fit spyder?....
Those rims look to be exactly like those on my 2013 RT Limited! And I reckon that if they came off another Forum member's Spyder, then there's probably gonna be a pretty good chance that they'll fit any other Spyder that takes 15" rims!
Shame they are so far away really... I've been looking for another pair of rims so that I can fit different sized tires on the spare rims without having to leave my Spyder boot-less while I'm stripping my 'normal' tires & fitting the testers or vice versa! But somehow, I think the cost of freight to South Aus might negate any potential benefit...
What???? They will fit any spyder. No difference between bolt patterns, just diameter of wheel. Has lower profile tire than older models with 14" tires and should fit under the front fenders of any spyder just fine.
So they will fit a 2012 RT that came with 14" rims? How would that work? fitment? speedo reading ect?
Yes...Absolutely. The wheel diameter is larger, but the outside tire diameter is the same as the 14" tires. Bolt pattern is the same on all models. Speedometer reads from rear tire, not the front. https://www.tacomaworld.com/tirecalc...5r15-165-65r14
if spray on bedliner doesn't last it was applied wrong. It's difficult to even scratch when applied correctly
maybe you're thinking of PlastiDip (or similar) paint
Looks like I pirated my own thread by facetiously suggesting the person wanting a set of black wheels could paint mine with truck bedliner.
NOT a good solution!
To be clear, these wheels are still in the pristine original aluminum, no bedliner to be seen, and it would appear could be used on most any Can-Am Spyder.
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
This thread got somewhat convoluted, what with the comic comments about spray-on Bed Liner and such.
No bed liner involved; just a pretty set of aluminum rims and low-mileage tires, still for sale and presently located in north GA.
I could deliver in the Tampa area after Dec 5, when I'm coming to my FL winter residence.
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
