Results 1 to 15 of 15
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default RT Mirrors - Loose - My fix
    With having to remove the Mirrors on the RT everytime the tupperware has to come off they seem to get more and more loose
    it also seems that the can be removed with little effort and could be prone to being removed by vandals although they would have to know
    the sequence
    BRP Sould have come up with a more friendly version - The fittings are prone to being damaged just in normal on/off operation if care is not taken
    Having said that I wanted to make my mirrors more secure and less prone to shaking whilst riding
    This is what I did
    I removed the mirror having marked at the bottom edge where the mirror fits against the bodywork - near to the Headlights
    I drilled a hole in the bodywork to take a Cable tie (Zip tie in US)
    I drilled a hole in the RT Mirror at the bottom edge so the 2 holes would line up once the mirror was back in place
    A Cable tie was threaded through the bodywork then though the mirror - Once the mirror was back on the Cable tie was pulled tight
    this secured the mirror to the bodywork - The cable tie sits below the mirror and is not noticable from the front but can be seen under the
    Mirror (The excess cable tie is cut off)
    When I want to remove the Mirror I just cut the cable tie and replace it with a new cable tie when refitting the Mirror
    The cost of a Cable tie is alot less than the cost of a replacement Mirror
    As with any modification Photos help to explain how it was done - So here are some and I hope it helps other who may want to secure their Mirrors
    SAM_0105 (640x480).jpgSAM_0107 (640x480).jpgSAM_0110 (640x480).jpgSAM_0108 (640x480).jpgSAM_0109 (640x480).jpg
    Eddie Sheppard
    Reading UK
    Spyder – RT-S SES (AUTO 2010 Model)
    List of Mods :-
    Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
    LED Bulbs Reversing Lights,Front position lights
    HMT - Brake Light
    LED – Running lights
    LED - Mud Flap lights
    Rear extended Mud Flap
    Sport Tall Wide Clear Windshield
    Utopia Backrest
    S/S Grills both sides matching
    Bottom Panel S/S Protection
    S/S stronger Funk Lid brackets
    S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
    Rubber Tank protector on glove box
    Grip Puppies
    Power Socket in Switch Cluster and at Rear passenger Handrail
    Rear Speaker Switch for passenger On/OFF
    Upgraded Front Marine Speakers
    Bluetooth On board Radio to Sena SMH10 Headsets
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    Also, periodically you need to take needle nose pliers and squeeze the little metal retainer rods back straight. The will bow out after repeated remove/replace. That usually fixes them right up tight again.
    That looks like a pretty slick fix!
    Now if I can work up the courage to take a drill to the Tupperware...
    Nov 2016
    Del City, Oklahoma
    Best fix i have seen to tighten those wobbly mirrors. Thanks a million. Mine definitely need something like your cable tie fix. pinching those wires together that grap the posts only works a few times.
    Invalid Emails
    Oct 2015
    morgantown west virginia
    they need to design the mirror mounting like Mercedes did theirs. a single bolt. the mirror head folds forward to access the bolt. piece of cake.
    just snapped my mirrors back on today, and they are a little loose at the front. already squeezed the clips. going to use the zip tie method on'em tomorrow.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I just bought a dozen of those clips and change them out when I popped a mirror off. They're available and not expensive. I mean, they're just really good paper clips. My solution but thanks for the idea when my solution no longer works.
    There is a VASTLY BETTER solution discussed here:
    http://www.spyderlovers.com/forums/s...imited-Mirrors
    It really makes all the other solutions look like archaic bandaids & works soooo much better than the OE fittings you'll be gob-smacked!
    This thread is five and a-half years old...
    There's bound to be some improvements over time...
    Phoenix
    Oct 2010
    Your right Bob (Might as well admit it)
    I thought I had posted this in response to this thread
    It was not intended to appear as a new thread
    As you read through the thread you will see Russell Culley has come up with a great idea for securing the RT Mirrors, So I will try a set of Magic Mirror mounts and use my existing Zip ties as a 2nd line of defence to secure the mirrors
    Removal of the mirrors in the future will be easier, Cut the zip tie and remove the mirrors as explained on you tube by Russell Culley
    https://youtu.be/gYxJjefNGoA
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Thanks Eddie!
    I've ordered his kit also, and am just waiting for the chance to try it out!
    Mar 2018
    south africa
    Default mirror issues.
    used self tapper in middle of mirror plastic to better secure , will also do cable ties mod .
    magnets good idea but just too expensive to south Africa with shipping
    regards
    Sep 2016
    clark county indiana
    Default machanic ?
    told the mechanic , tape a little on the mirror , only the mirror ... dang , she doesn`t seem too care this stuff cost money ! ( she is a bit touched )
    Sep 2016
    Default seriously though
    I am looking into the majic mirror inserts for sure ! will check with blue /911 guy ! ( soon as I get uhmmm free )
    Dec 2015
    Oakley Utah
    Quote Originally Posted by ddtoit View Post
    used self tapper in middle of mirror plastic to better secure , will also do cable ties mod .magnets good idea but just too expensive to south Africa with shipping regards
    Make your own. There's a thread from last year showing how to do it.
    2014 RTL Platinum
