Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: shifting
    Apr 2014
    Felton Delaware
    Default shifting
    When shifting on the automatics do most go by sound or use rpm,s. Just bought a 2014 STS for my wife and its her first bike ever. I myself go by sound when I test rode it but was just curious.
    Jul 2011
    Mitchell, Ontario, Canada
    Start out by shifting by rpm. Then as you get used to it you will change to how it sounds. Upshift at about 5,000 or higher. Never cruize in 5th gear below 4200. It will downshift for you if you are busy or lazy. But if you don't come to a stop. Downshift manually before twisting the grip. Hold the throttle in a steady position during shifts. The computer will handle the rpm thing.
    2018 F3 LIMITED
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Starting with a 59 Rambler and up thru today, regardless of car or bike, I have always shifted by sound.
    AJ
    Quote Originally Posted by poppajim View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Billybovine
    also remember not to ease off the gas when shifting. Stay on the gas and hit the paddle....
    Jun 2018
    Rhode Island
    I have heard a lot of people saying to hold it steady while shifting but I find that shifting while accelerating is much smoother. I still shift at higher rpm's (5,500 +/-), but do so while accelerating. IDK... I could be doing this shifting thing all wrong but let me tell ya, it shifts like butter
    RE Shifting:
    The two cylinders like to be shifted in the 5500 rpm range. The engine "comes alive" at that point.
    The three cylinders like to be shifted in the 3500 rpm range.
    I know the sound for each of mine and usually shift by ear.
    I leave the downshifts to the unless I feel the need to punch it for more power.
    Your should be in the "ballpark" but you need to find your "sweet" spot.
    And regardless of engine--no need to "roll off" when putting it into a higher gear.
    Jun 2010
    Las Vegas
    Quote Originally Posted by PaladinLV View Post
    AJ
    AJ, it is a good thing that you have a 1330 because if you were shifting a 998 by sound you’d be lugging it and making costly clutch repairs.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    Some have suggested beginners keep it in trailer mode for better shifting points I know it took me some time to get use to the higher RPMS
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    The 1330s are so un-fussy, that it doesn't matter when you shift them. As long as the computer will allow the shift to occur: go for it!
    (I shifted by sound)
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by jtonga View Post
    Joe
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    I try to shift by sound but sometimes I have trouble hearing the engine so I'll peek at the tach. I shift between 5500 and 6000. I usually downshift manually to 2nd but then let the computer do the 2 - 1 downshift.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Apr 2017
    North Central Florida
    Doesn't matter.
    Do whatever feels right FOR YOU.
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default Hmmmmmmmmmmmmm
    Billy, I usually run in the 3000-3500 range, regardless of gear. Why do you recommend the highlighted above?
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Mar 2015
    forrest above Reno, Nv
    Wink 998 motor
    Hi Ray,
    I think the person you quoted was referring to the 998 V-twin motor.
    I downshift more for the situation. I want to be in a gear that will allow "brisk" acceleration with out down shifting. Old motorcycle habits die hard.
    Lew L
    2014 RTS , Circuit Yellow
    Greenville Tx
    The 2014 998 twin really likes the high RPM's. Dont be shy and keep it high! The Power band is much better up above 5G's
    2017 F3 Limited
    Apr 2017
    Quote Originally Posted by AY4B View Post
    Desirable for some riders but not really necessary for a pleasurable ride.
    Sep 2014
    tenino, wa
    Default May have the answer to my question
    If Billy meant the 998...…..I have the 1330 engine.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Mar 2016
    Indiana
    I shift my 998 in the 6000 - 6500 range. It shifts smoother at that range, than if I shift at a lower RPM.
    Quote Originally Posted by teninospyder View Post
    He did; that advice is best applied to the 998s. It'll keep you from toasting the engagement clutch on those models.
    SE-equipped V-Twins have a centrifugally-engaged clutch
    The triples have one that is hydraulically engaged.
    Jun 2015
    Hampton Roads, VA
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    Yes about 5K to 6K, throttle steady. I read here somewhere you never want to be below 4K RPM? Something about the clutch is fully engaged around 3800 or so? It does take some getting used to between the 1330 and the 998! We have both and it freaks the wife out on the 998 revving so high.
    Jul 2011
    Quote Originally Posted by stevencovert View Post
    The whole clutch engagement minimum rpm for SE5 models has been sliced and diced. But still the common concept the low rpm can prematurely destroy the clutch is true in fact, but extremely exaggerated to the point of being a lie. The clutch published stall speed is 3200 +/- 200 rpm. So as long you keep the rpm above 3400 rpm. There will be no premature wear on the clutch. Also the lower the gear you are operating in will reduce the load on the clutch. So driving in 1st gear at 2500 rpm for a short period of time. Like a city block. Is not going hurt anything. The problem that BRP found out in the early days was that folks where driving down the road at 2500 to 3200 rpm. In 5th gear. Into headwinds and up hills. Burning out the clutch in the process. Clutches are not covered under warranty. But BRP would replace a clutch under goodwill. Only if the rpm profile showed that the Spyder was not operate at a significant time under 4000 rpm. If it was tough luck. The reason you drive with a minimum of 4200 in 5th gear. Is because of the engine power profile. So it does not matter whether it's a SE5 or SM5. The engine just runs better there for the load it is under. 4th gear lower load 4000 min. 3rd 3800, 2nd 3600. That is for flat road with little headwind. Steeper the hill or stronger the wind. Up the rpm accordingly. But as long as you are over 3400 with an SE5 don't worry about the clutch.
    2018 F3 LIMITED
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    didn't know them made the twins in 2014???? I thought that was the year BRP went to 3 cylinders??
    BIG F
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Big F View Post
    BIG F
    2014 3 cylinder was the RT only. RS and ST still had the twin and did right up to the end of their production. In 2015 the F3 came along and got the 3 cylinder too.
    Trb-- (Roger)
    BIG F
    They were still making RS, ST, models. When the F3 came out, the RS and ST went away. They will correct me if I am wrong.
    Apr 2017
    Pittsville Maryland
    Default downshift
    i have a 2015 st 998. i run in trailer mode- it downshifs at the correct rpms 3500 , and i dont have to down shift.
