Results 1 to 16 of 16
    Jun 2015
    Hampton Roads, VA
    Default How many bars for heat do you see on your GS/RS V-Twins?
    Hi all,
    I get 5 bars on the heat gauge of my 2008 GS. While riding with an RT that has a VTwin, they were at 3 bars, flickering on 4. I haven't yet pulled off the two panels underneath to let engine heat out, worried a little about rocks getting kicked up. IDK if the RT's have a different radiator, more coolant, etc.
    - Put in some WET, the stuff that makes water get into all the nooks
    - Today I pulled the side panel off and used engine cleaner to hose down the radiator and the mesh screen in front of the radiator. Then used a power washer to clean everything sparkly.
    - I d have an HMF exhaust and a juicebox, but cannot fathom how those could affect heat. But open for theories.
    Still 5 bars. So wondering what you see going down the road for your heat indicator on your GS/RS 998cc models!
    Thanks,
    Steve
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by stevencovert View Post
    Hi all,
    Thanks,
    Steve
    Your GS is correct 4 or 5 bars is normal. Your RT running at 3 bars all the time could be a problem. New thermostat time.
    2018 F3 LIMITED
    Sep 2013
    Johnson, Vermont
    My RS normally runs 5 bars. The exception is if its colder out (40's-60's) then it typically runs 3-4 bars.
    Jun 2015
    Hampton Roads, VA
    Thanks guys, I'll stop worrying about it!
    Active Member Gonzo5776's Avatar
    Aug 2018
    Woodbridge VA
    Default 5 stars on my RSS
    In this 90 degree weather my spyder stays at 5 stars.
    2012 Can Am spyder RSS
    Weekend rider
    Nov 2008
    las vegas, nv
    My old 09 used to run at 5 bars but new to me 2015 model kicks fan on early to keep it at 4 bars even in 100 degrees weather.
    Probably not a whole lot of difference but makes ME feel better.
    6 states down 42 states to go
    Nov 2008
    Edmonton / Alberta
    In stop and go traffic , on a scorching hot day I see 5 bars frequently, as soon you start moving it goes down rather quickly. I normally run around three bars.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Steve,
    Re: I get 5 bars on the heat gauge of my 2008 GS.
    I also get 5 bars on my '08; I've gotten used to it.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Oct 2013
    rome new york
    depends outside temp usually 3-5
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Consistently 4 bars on my ST. As someone else said, on really hot days in stop and go traffic it might touch 5 but goes right back down as soon as I start moving. On chilly mornings it may stay at 3 bars for a while but eventually settles at 4.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    My 2010 RTSM5 runs about 5 bars
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Aug 2012
    CO
    3-4 under normal operation, 5 if it's mid July and I'm stuck in traffic. we have the Spyderpops cold air kit.
    JLohPhotos
    2008 GS , Millennium Yellow
    Apr 2018
    La Cresenta California
    i took off the panels and used some oven cleaner on the radiator let it soak awhile at the car wash then pressure washed all the gunk off. in stop and go traffic 4-5 bars is normal if your on open road it should hover at 4, if it reaches 5 bars you should hear the fan kick on and feel the warm air out of the side panel and see 4 bars. on cold mornings it will hover around 2-3 on the open road. until it warms up. i recently changed the thermostat too so i am seeing better cooling.
    2008 GS SMS 5 , stock stock silver black
    This is an older post. August/2018 was the last reply besides today.
    Aug 2007
    Greeneville, TN
    5 bars on a hot day, not a problem. BRP is in Canada where it doesn't get hot. The gauge reads high. But as long as it reads the same high, it's just fine.
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    The best substitute for brains & knowledge is....................silence.
