Results 1 to 25 of 29
    Aug 2018
    Austin,Tx
    Default Newbie questions
    I’m looking at 2015 RT Limited. Owner states she had difficulties getting to speeds over 70 on hiway. She thought there maybe a governor to limit. I called dealer service advisor who said he had not heard of this. I thought I had seen something on forum regarding this and would appreciate some real world advice.
    In addition, any thoughts on priorities of upgrades. Seemed to me sway bar and belt tensioning would be at top....
    Thanks in advance!
    Jrod
    ATX
    Apr 2017
    North Central Florida
    Of course that is not normal at all.
    And I would advise NOT considering it as a good purchase unless and until that speed limitation problem gets fixed.
    As for other mods......as needed only.
    NONE of the most common "fixes" are needed by every owner.
    ECO Mode is probably engaged...
    Another possibility might be that she had trouble rotating the twist-grip throttle far enough...
    Active Member Elliott 76065's Avatar
    Mar 2018
    TX
    Default Suggestion
    Do you know any local experienced Spyder owners/riders that would test ride this bike and evaluate it for you, if the current owner will allow that to happen to help with your decision?
    [QUOTE=Jrod;1386511]I’m looking at 2015 RT Limited. Owner states she had difficulties getting to speeds over 70 on hiway. She thought there maybe a governor to limit. I called dealer service advisor who said he had not heard of this. I thought I had seen something on forum regarding this and would appreciate some real world advice.
    Thanks in advance!
    Jrod
    ATX
    Rick & Kathy
    ETX
    2021 RTL
    2017 F3T , silver black
    Apr 2014
    Beloit Kansas
    as an ECO mode user, I'm sure that won't hold down your top speed. I do agree with Bob that probably
    there is a loose nut between the bars and the seat.
    Add ons ? You need to decide after you learn to ryde. If those two items you mentioned were a "have to"
    don't you think they would already be there ?
    stay safe and let's get into the three wheel world.
    Aug 2018
    Austin,Tx
    i was a good boy and did not bring the twist up as a possibility. I thought the eco mode was more of a suggestion not so much mechanical?
    Jrod
    May 2013
    Indiana
    You don't mention the mileage on the 2015. I have a 2015, and per the Owner's Manual, I have had it to my servicing dealer annually(3X). IF the owner has followed the OM, I wonder why she has not mentioned this problem to her dealer. Depending on the 2015 month of purchase, and/or unless she purchased the BEST(or any) extended warranty, the Spyder could be out of warranty.
    Mike
    2021 Marsala Red Metallic RT Limited
    Aug 2018
    Austin,Tx
    Default Newbie Questions
    I thought eco mode was more of a suggestion than mechanical rule?
    I’m hoping grip strength played the biggest part....
    Apr 2018
    Tomahawk wi
    Default Questions
    Quote Originally Posted by Jrod View Post
    Thanks in advance!
    Jrod
    ATX
    I WOULD MAKE SURE THAT THE SPEED PROBLEM IS FIXED BEFORE BUYING IT PARTS AND SERVICE ARE EXPENSIVE. AND MAKE SURE YOU BUY FOR A GOOD PRICE l bought A New f3s 4 months ago $19000 before Tax Trying to get $1500] no one is interested
    Aug 2018
    Austin,Tx
    Quote Originally Posted by MikeT View Post
    Mike
    1750 Miles
    Extended warranty’s mechanical + tires
    purchased new, dealer serviced she states.
    I would ask pre purchase dealer check for contingent offer.
    Apr 2015
    Tucson, AZ USA
    As others have said, nothing normal about being speed limited. Exercise Caution!!!
    As to upgrades: I've spent over $8K on upgrades on my RT and I wish I had waited a good long time before I did anything as I think many were "just because" vs. actually needing them.
    Rob
    Aug 2013
    Northern California
    That motorcycle will go well over 100 mph. Perhaps she isn't aware that it has 6 gear! That being said, I would take it to a dealer and have them check it out to make sure there is not something wrong!
    Aug 2018
    Austin,Tx
    Default newbie Questions
    Quote Originally Posted by robhowen View Post
    Rob
    Good advice sir. Thanks
    Jrod
    Default Interesting....🤔
    These machines do have a Rev (RPM) limiter on them you may know it as the red line....Other than that there is no reason for it not to go well over a hundred other than the driver not being comfortable being there. There was only one time I ran into this problem and it was that there was an obstruction in the air intake and if you got on the gas it would limit the air intake. Not likely here. Good idea to test it yourself or have someone test it for you. Would not suspect any major problem with this machine....
    Faribault, MN
    JRod, I'm thinking (if you want) you can hit 70/75 (I just went for a spin to check this) in 2nd gear, but if for instance she was already in 6th gear going 60 and just twisted the throttle it might "lug" a little as the starting RPM's would be very low. You might be able to ask her to be more specific about what she was doing when she "felt" that.
    Some of the other triple riders here likely know the recommended RPM / gear ranges for speeds. I agree with the others that have said a properly maintained Spyder can easily get to 70 (assuming the proper gear/RPM usage).
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default How does that song go?? Hey buddy how, do I get this car,,, Out OF Sec Ond GEEEAARR
    Beep, Beep, BEEEP < BEEEEP!!
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    All above are right on. Make sure you get it checked out before putting your money in. Most likely "scared pilot" syndrome. Should have no problems winding it past 100 (if you dare).
    ECO Mode slows down the throttle response, and (I think!) it also limits you to about 60% of full-throttle...
    Whenever I tried it out: the bike felt sluggish, and it was VERY noticeable!
    Jun 2011
    Kerrville, Texas, USA
    Default I gotta ask you -- how'd you get to $8K in upgrades?
    Rob
    Other than "Practice, practice, practice..."
    I'm about to embark upon my first round and I am willingly reaching for the wallet to do so, but I'm not seeing $8,000 as even a possible destination! :-)
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Eight thousand in Farkles is a nice start...
    I have over 5K added to my 2018, and it's only 6 Months old!
    My 2010 had 10K, and my 2014 had 9K on them...
    And if the Missus sees this: I'll deny ALL of it!
    Aug 2018
    Austin,Tx
    She said she had a rider on back and could not get over 70 ....”all my friends left me in the dust”. I will make some inquiries to her. She mentioned hearing of governor is why I was asking as I had never heard before.
    Thanks foe help.
    JRod
    Sep 2011
    Acworth, GA
    my 2015 RT will do well over 80, uphill, riding 2up, and were both plus size models, ok maybe the model part is a stretch.
    I am only aware of 1 thing thing that would "govern" the speed- Limp Home Mode. In corners VSS (Orange lizard on dash) will slow you down to keep 3 wheels on the ground but it's just momentary. Good Luck
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Quote Originally Posted by bhern View Post
    I'm at 10K and it's hard to even see where it went. Fortunately, I made a list each mod with price so.. lots of upgrades...
    I thought I was pushing the limits on my 2008 and 2009 with $6K worth of farkles on each. You outdid me. I have been much more conservative on the 2010, 2011, and 2014.
Tags for this Thread
