Results 1 to 25 of 30
    Jun 2018
    Default syn vs regular motor oil
    I'm trying to decide on syn or blend motor oil. i know the manual says use a blend but for my next oil change aim wondering if the full syn would be better .does anyone have info if there is any clutch slippage exc ? which may have me think the blend would be a better choice . it is a 2014 rt limited 1330 Thanks Vic
    Northern Kalifornia
    Default Blend is ok......
    Just make sure you use wet clutch specific application. Also keep in mind your oil lubricates your transmission so you also have the shear factor to consider. Check out the available brands of oils made specifically for motorcycle use and you'll good. You are likely going to receive no less that 200+ responses to your question because it is the MOST debated topic on this site.
    Default best oil ?????
    Quote Originally Posted by Vic View Post
    Even considering cost Syn. is the best way to go ..... Right now there is a HUGH rebate on Rotella T-6 which is the right type oil for the 1330...... Walmart even has it on sale , so the rebate is even better ............... Mike
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I have a 2015 RTL and up until 23K miles I used the BRP 1330 blend. At 23K I decided to go to full synthetic and went with BRP full synthetic, mainly based on Sierra Cycles recommendation. I didn't know what to expect, but in other bikes when I went to full synthetic it tended to result in an engine running noticeably cooler, better shifting, and generally a more mechanically quiet engine. With BRP full synthetic the only very slight difference I see is the engine running just a tad cooler. I mostly tell this by how infrequent the electric fan comes on. In AZ the electric fan is not uncommon, particularly on 105+ degree days for in-town riding. I expected more, but this may mean nothing. It might be as simple as the BRP blend is very good.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Feb 2017
    Lodi, CA
    Default oil
    Synthetic oil is good. You can also use Microlon Engine Treatment, which I used in my Airplane Engine.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    You have misread the manual and specifications!
    " Use the XPS 4-STROKE SYNTH.BLEND OIL (SUMMER) (P/N 293 600
    121) or a 5W40 semi-synthetic (minimum)
    or synthetic motorcycle oil
    meeting the requirements for API service
    SL, SJ, SH, SG or higher classification.
    Always check the API service
    label on the oil container."
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Default Oil
    Use an oil synthetic or not with the proper ratings for your engine and change it when needed and you won't ever have an oil related failure......
    Synthetic or blend: why not just use the BRP oil that your Dealer sells? After all; the engineers are hanging their reputations on it...
    Jul 2018
    Fountain Hills,AZ
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by moogully View Post
    Being a wet clutch with a shared oil supply, I'd recommend against using any additive to the oil. What's good for engines is sometimes not so good for wet clutches.
    2020 RTL SE6
    Default Choices, choices
    Not that different when comparing a synthetic blend and a full synthetic . Not so with a full synthetic and a non synthetic one. Guess it is more going with a good brand name oil. I use XPS blend and am happy with it.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2017
    North Central Florida
    BAD idea.
    A quick Google search looks like this probably is Moly (molybdenum disulfide) which is specifically BAD for wet clutches.
    As is PTFE (teflon) and other "super slick" snake oil additives.
    NO additives in your oil. NONE.
    You only buy stuff like this: when you've got a squeaky snake!
    Dec 2017
    usa
    Default oil
    Are these the same people that recommend Kendra tires?
    Jul 2011
    Mitchell, Ontario, Canada
    The difference between the BRP Synthetic and Blended is small. According to XPS lubricants the blended is 95% synthetic. So really if you want to use the BRP stuff. I would not worry about it. Now in the aftermarket I would go with a full synthetic because they are not going to tell you how little synthetic is in the blend.
    Apr 2017
    So, I'd be REALLY interested in hearing what XPS Lubricants has to say about what perceived advantage there IS with blending in that 5%.
    I find that a little hard to swallow; why bother ??
    easy,
    Don't you remember your Grandmother telling you that "Everybody has to eat of pound of dirt; before they die."?
    There you go...
    BAD idea.
    +1!!!
    Specifically, from my operator's guide immediately below the recommended API oil service codes,
    "NOTICE Do not add any oil additives
    to the recommended oil. This may lead to
    gearbox and clutch malfunctions."
    Jul 2011
    Don't know. Why not ask them?
    Apr 2017
    Anyone who really cares should ask.
    I don't.
    I was kind of hinting at: Maybe the person who got the initial answer should follow up......for the benefit of all.
    May 2009
    Connecticut
    If your going to use Synthetic- Make sure its Motorcycle Oil JASO 2 Rated!!!! Two is BETTER THAN JASO Rated?
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member GaryinWI's Avatar
    Dec 2014
    Western WI
    Default Semi-synthetic Blend
    I have purchased 3 new bikes, a Kawasaki, a Victory and now a Can Am. ALL of them recommended using a semi-synthetic oil. Victory stated that semi synthetic results in engine running 5-10F cooler. I have been in Powersports for 50+ years and I have never seen a lubrication-related failure other than loss of lubrication (low/no oil or pump failure). There is nothing wrong with using synthetic oil, it just costs more with no apparent advantage. If synthetic was better wouldn’t the manufacturers recommended it? Just my 2 cents.
    2017 F3 Limited , Gloss Black with red and carbon fiber accents
    Active Member vindex1963's Avatar
    Jul 2018
    Payson AZ
    Have to love oil threads, such passion.
    2012 RT A&C SE5
    2015 Victory Cross Country (Dyno tuned 118hp 116tq)
    2006 Triumph Rocket Dyno tuned 140hp 154tq)
    Quote Originally Posted by vindex1963 View Post
    If you love oil threads: you'll REALLY love tire brand and air pressure arguments.
    Boerne, TX
    Bob, should I use 10w-10 or 10w-60???? Half regular and half syn??
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
