Results 1 to 19 of 19
    Member SpyderTomRT's Avatar
    Aug 2018
    Grenada, MS
    Default 2015 RT replacement Front Wheel
    New to the forum, had my RT a little over a year now.
    Anyone have a replacement stock black front wheel that you want to sell?
    Found out out how much my wheel is bent when getting the new tires mounted. Seemed that the guy I bought the RT from had Ride On put in and I never noticed any vibration until the new tires were mounted. Not it real bad vibration, but enough to bother me at highway speeds.
    Thanks for for any help!
    Default NEW WHEEL
    Quote Originally Posted by SpyderTomRT View Post
    ....... How do you know your wheel is " BENT " ......Ride on will not cause this .....Mike
    Aug 2013
    SF Bay Area
    Ride-on doesn't stay with the wheel. New tires mean new balancing so, ya, how can the wheel be bent?
    2021 F3 Ltd , Magna Red
    Houston
    The wheel was already bent. The Ride on was masking the problem at least partly. Now with a new tire its more obvious and he wants a new wheel. The Ride on did not bend the wheel.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default BENT WHEEL
    Can - CAST Wheels - BEND ...... I would think any impact strong enough to BEND a Cast wheel would crack it ..... imho CAST wheels don't BEND ................... but I'm willing to be educated on this ... Thanks .... Mike
    Regardless of what happened with the wheel... , and I hope that you find what you're looking for!
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Cast wheel will bend.I have seen it often on cars.To much of an impact will crack them.
    2018 RT Anniversary , Brake pedal extended
    Default CAST WHEEL
    Quote Originally Posted by Ex Winger View Post
    Live and learn ..... Thanks ....Mike
    Houston
    Yes, they do. Just not far but have seen more than one or two bent CanAm wheels.
    Aug 2018
    Grenada, MS
    I am sure that the Ride On was being used to correct the vibration caused from the wheel that has a slight warp in it, saw this myself when the new tire was mounted and it was being balanced at the tire shop. I know that Ride On will compensate enough to take care of it, ive used it before on motorcycles. Since I have discovered this, I am more interested in replacing the wheel completely.
    Thanks for the help!
    Aug 2018
    Grenada, MS
    I am wanting to replace my 15 RTS stock front wheel. My wheel is the blacked out version. Hoping to find someone who may have changed theirs out and was interested in selling one.
    Thanks!
    Default BENT WHEEL
    If your certain the wheel IS bent ..... I'd find out WHY & HOW this occurred ..... A bent wheel was caused by a nasty hit, I'd be concerned about what else might have been damaged and if it was fixed ????? ...........Mike
    Aug 2018
    Grenada, MS
    There is no other damage that I can find, put about 5000 mi. on her since buying, I’m the 2nd owner.
    The wheel isn’t noticeable when riding, but when it was placed on the balancer, you could see it. Very slight, but still there. I am not concerned with anything but replacing the wheel.
    The original owner was a handicapped vet of the Vietnam War, walked with a cane, God bless him. Best guess is that he hit a curb with it, but the original tires were still on it and did not see any noticeable damage to the sidewall. Not a real big deal, everything checks out fine, alignment is good and no abnormal wear on the old tire. Vibration is felt at highway speeds only, not terrible and not much noticeable except when holding the bars, you can only feel it.
    I could just put more Ride On in and it will probably take care of it, but I feel better replacing it.
    Thanks for the comments!
    Tom in Mississippi
    Apr 2017
    Temple, Ga
    I have one that was taken off my 2015 RT-S. It has a very small scuff that the tow truck driver put on it. I had to Rt for 11 days and got the DSS error so it had to be towed to the dealership. They wanted to repaint it, but since it was so new i said no.
    2015 RTS , Black
    Aug 2018
    Grenada, MS
    Quote Originally Posted by grandbug View Post
    Thanks, I’m interested
    PM sent.
    Tom in Mississippi
    Aug 2018
    Grenada, MS
    Default Bonneville style wheels
    Well, I finally pulled the trigger and went with a completely different look after trying to locate another wheel to replace a bad one that I find out about when I got new tires. Not sure what these are called other than Bonneville style, so far so good. Really like the simplistic look, should be easy to clean. Ride is perfect, completely eliminated that vibration I was getting at 55.
    Has anyone tried getting a wheel “trued”? I think I may hold onto the originals if I can get fixed or may sell the one that is good, bit undecided at the moment.
    Tom in Mississippi
    Apr 2017
    Temple, Ga
    The wheels look good. I am glad that you found some wheels for it. I wish that my wheel had been a match and saved you some money.
    2015 RTS , Black
    May 2017
    Mesa, Arid-Zone-A
    GREAT looking wheels
    Semper Fi
    Aug 2018
    Grenada, MS
    I wish it had, too. Appreciate the offer. Going to try and have the bad one fixed if possible and hold onto the original set, but I maybe able to help someone out just as you reached out, never know.
    Thanks, again,
    Tom
    Tom in Mississippi
