Results 1 to 9 of 9
    Jul 2018
    Lake Stevens, WA
    Default 09 Roadster - OEM Fog lights
    brand-new to the spyder and absolutely loving it! came from a piaggio mp3 500... wanting LEDs all around. while there are headlights in the headlight bays, there are (currently) none in the fog bays. what do I need please and thank you!
    2009 GS , MSD wires Red/Black
    Default GS - FOG LIGHTS
    Quote Originally Posted by CANUSASwede View Post
    ...& .. ..... I'm not sure BRP ever made Fog lights for 09 GS body panels ..... But if they did check a parts fiche ( cheapcycle.com ) ..... or you could DIY a pair of small ( but powerful after-market LED's ) into the holes .......or you do what I did, and use the scoop as an intake for the AIR BOX, so the throttle bodies get much COOLER Air ...... Mike
    Nov 2008
    las vegas, nv
    eBay!
    Something like this or brand new unopened item can be had for $350-ish time to time.
    You can replace the bulbs with LED or hid.
    2-4 hours of labor or $2-300 for installation.
    If you are planning to do bajaron’s anti-sway bar, it would be a good idea to do them at the same time to save on time to take down the frunk. Although not necessary for anti-sway bar, it’s just easier with frunk off and you do need to pull frunk off for fog lights.
    https://m.ebay.com/itm/CAN-AM-SPYDER...IAAOSwx0ZbdYx9
    6 states down 42 states to go
    Jul 2018
    Lake Stevens, WA
    elaborate please
    Default COLD AIR INTAKE
    elaborate please
    Go to my Albums ( Bio page ) .... pics with words are in the album " cold air - for air box on GS & RS " if you click on a pic it will have an explanation at the bottom ...... not hard to do ...... Mike
    Mar 2016
    Indiana
    ...& .. ..... I'm not sure BRP ever made Fog lights for 09 GS body panels .....:
    They did make fog lights. That is what they used in Europe for low beams. I don't know how easy it will be to find them, now that they stopped making the RS model.
    It's getting hard to find the BRP HID headlight kit's for the RS's.
    Default Little checking.....
    I got the panels and the light frames from cheapcycleparts.com.They also have the light but for the European models. I got them to install turbo fans and ducts to the Airbox and rear cylinder at the throttle body...they had kit and you might find them .
    ​2012 RS sm5
    Jul 2018
    Lake Stevens, WA
    that kit have a part # to associate with? kinda really kewl looking mod
    Default Sorry....
    little late getting back but no you just have to order the parts indivisually. Cheapcycleparts.com has the breakdown and to the side you will see the euopean parts. the fans and tubes are from ebay or auto parts. You can see some of the inside on my albums in my profile....
    ​2012 RS sm5
