Results 1 to 9 of 9
    May 2016
    Vancouver Island, BC, Canada
    Default RT Bike Lift Options
    This has probably been debated previously. if so, my apologies!
    Looking for a lift for a 2013 RT-S, it looks like a choice between the Big Blue Lift and the J&S Jacks (with the requisite Spyder adapters). Both seem capable of doing the job.
    Any input would be appreciated before I pull the 'purchase' trigger!
    Thank you all.
    2023 900 Sport , Nitro Blue
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    This is one of 12 bookmarks I have on lifting/jacks for the Spyder
    http://www.spyderlovers.com/forums/s...Lifting-the-RT
    "Search" will lead you to any others you may want
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Oct 2016
    Faribault, MN
    Quote Originally Posted by ryu1867 View Post
    Thank you all.
    Sure spend THAT money, or get a $89 Harbor Frieght 1500lb lift with some basic Jack stand and spend the rest on farkles. Let's see I've done 5 oil changes, Wheel and Tire changes, Ron Swaybar install, Shock adjuster install, R&R my ACS system, installed Air Ryde rock Armor, and more over the last few years.
    But, if you really need the prestige of owning the Big Blue or J&S, (plus adapters that cost as much as the HF lift) they're VERY worth the extra money you'll spend on them, I hear anyhow.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default I have
    I just recently purchased a J&S Jack, while the shipping is less than desirable, the jack and adapter itself are very well made. I recently used it to remove front wheels in order to install fender leds the RT was super stable. Just because I can and I wanted to I raised the bike to the jacks max lifting height put the stops in place released pressure off the jack, I was able to climb on the bike and rock back and forth and shake the bike, I had zero feeling of the bike tumbling or jack twisting and the bike taking a dump. In my opinion the jack is well worth the money and I would highly recommend it.
    Just know the website says 2-3 weeks, they really need to change that to say 7 weeks!
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Here's a video I did with my Big Blue...
    https://youtu.be/yNXpiJLixok
    2014 RT-Ltd , Cognac
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    I use my car hoist ,works for me .Do not know how to posts pics.
    2018 RTL , dark blue
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    I have the Harbor Freight and was always concerned about how much it wobbled as it was jacked unit I braced the Spyder once it was up... just took delivery of the J&S (with Spyder adapter) and love it. The confidence it gives me in its stability while be jacked and in the air are worth the extra cash for me.
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    May 2018
    millsboro,delaware
    Quote Originally Posted by stmike 1800 View Post
    I have a car lift too,so how did you lift the spyder with that?
    : 2017 RTL ORBITAL BLUE
    Mar 2018
    Front pads just behind the front tires ,and the rear just inboard of the drivers floor boards .
