Results 1 to 9 of 9
    Feb 2016
    HAWTHORNE nj
    Default Vent install question
    Hell guys. I am about to install a set of vents and my question is .is there any thing else I need that does not come in the kit from BRP.thanks….
    Jun 2016
    indpls in
    Default vents
    i took the panels to the dealership after i taped up the area to be cut out and they have a template to mark for the cutout
    Feb 2016
    HAWTHORNE nj
    Default Thank you
    I plan on doing this myself. I only hope it comes with some instructions.
    Oct 2016
    Faribault, MN
    Here's a pic of the back of my right side panel cut out for the vents.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Once you get up enough nerve to make the first cut, it gets easier after that. Good Luck
    Oct 2015
    alberta and a.z
    Default vent install
    I only drilled two one in holes and worked great without cutting to much out. Doc riverside sent instructions so he might still have them. Not scary if you are patient.
    Feb 2016
    HAWTHORNE nj
    Default Thank you
    I opened up the box and there where no instructions or template ...does any one have one I can buy or use . not afraid to cut just want to read up on what needed before I start.
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Do a search for Doc Riverside, he has all of the instructions and info. on the forum here.
    How old would you be if you didn't know how old you were?
    Feb 2016
    HAWTHORNE nj
    Default Hello there
    Guys the mod is done. making the cuts where not that bad at all. on to the next mod. Dave thank you for the info on the flash. I will be getting that done during the winter months.
