CB and bluetooth
With a 2015 RTL, if I add the CB radio, will that work with the Sena 20s Bluetooth headset, or is that a wired headset only feature?
I want to be able to reach a little farther than just the Bluetooth connection.
Pretty sure that the BRP integrated CB is headset only.....and it is $$$$.
J&M has one that mounts on the left handle bar (some minor alterations needed for the mount, I think) but they have a Bluetooth model and it's not quite as expensive as the OEM one.
We installed the J&M CB on Louise F3T and integrated it with the Sena headset. Works very well indeed.....for 50 year old analog radio technology.
JIM EVANS
2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
SpyderLovers Sponsor
A CB THAT WILL NOT BRAKE THE BANK
I can get you on the air using a CB on your Spyder AND IT'S BLUETOOTH
for around $300, I have a bunch of them out here on Spyder Lovers using
this setup... CALL ME for DETAILS
Dave
Ride Safe
