Results 1 to 12 of 12
    Active Member Reacher68's Avatar
    Jul 2018
    Grand Prairie, TX
    Default Headlight install
    I installed Lamonster LED headlights today and they are great! I did run into an issue though. On the left light, there are 2 caps on the back of the light that keep popping off and don't seem to stay in place. This leads me to a couple of questions before I screw the light back on:
    • Do these caps have to be on? Will it hurt anything if I leave them off?
    • Since they won't stay on their own, should I use silicone or maybe gorilla tape to hold them on?
    • What are the caps for?
    Any help is appreciated!
    2016 F3-T
    Places I've ridden.
    NorCal - Northbay
    I believe those are the adjusters for aiming the light (up/down, left/right).... I would only worry about them being on there if you use water to wash the byke. Corrosion may be a problem down the road. But even then, how often does one really need to adjust their headlights....
    Chuck
    Jul 2018
    Grand Prairie, TX
    With the help of a couple people on facebook, I determined that those are vent holes so the light doesn't fog. I used a little bit of glue around the edge of the caps and now they stay on just fine.
    2016 F3-T
    Places I've ridden.
    Jul 2018
    Grand Prairie, TX
    After having the new bulbs installed, the headlights are a bit too high. I think it's bad for oncoming traffic and the high beams are useless unless i want to see up into trees. Is there a way to adjust the direction of the beam. Could I use a washer and shim the screw at the top of the housing to get it to point a little lower?
    2016 F3-T
    Places I've ridden.
    Nov 2012
    North Las Vegas, NV
    The adjusters are under the top side panel you removed to get at the headlights. Small brass screws if I remember correctly.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2018
    Grand Prairie, TX
    I'll look for them, thanks. I might even read the dreaded manual.
    2016 F3-T
    Places I've ridden.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Reacher68 View Post
    Refer to page 125 of your owners guide. Detailed instructions with labeled diagram showing the location of the adjuster.
    Sep 2018
    Georgia
    Awesome post.
    I'll be doing this to my wife's F3T soon i'm sure.
    Jul 2018
    Grand Prairie, TX
    I don't know that I really understand what panels I have to take off to access that adjustment screw though. It tells you sorta where it is and how to adjust it, but it doesn't say what you have to do to get to it. Not that I could find anyhow.
    2016 F3-T
    Places I've ridden.
    Jun 2018
    Melissa, TX
    Default Adjusters
    It is under the big side panel. Watch Lamonsters video, he points it out.
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default Headlight adjustment
    You don't specify what model bike you have, so this may have change over the years. For the 2018 RT Limited, it's very easy. Remove the panel (see picture) Adjust the headlight by turning ( see picture).
    2018 RT Limited "Blondie"
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    This is the F3 forum, so likely it's for an F3?
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
