Results 1 to 12 of 12
    Active Member rkba101's Avatar
    Dec 2016
    Green Cove Springs Florida
    Default No Idea HELP Plz..
    Hard to explain.. Only happens when Im playing really. If I shift gently and not getting on it she doesn't do this.. When Im changing gears above 6k she rpms drop and she then picks up again? Someone stated maybe gas filter but ?? Thanks.. I have the 2013 STS model smaller engine..
    My Ride --->>> 2013 ST-S SE5 <<---
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    How much drop, how long, gradual or rapid recovery?
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    Mar 2013
    Are you letting up on the throttle when you shift? If so that will cause this as the Spyder is programmed to automatically lower the revs as it shifts. By manual lowering the revs first it confuses the computer. You may not know you are doing it.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2015
    Chardon, OH
    That's right. the computer takes care of blipping the motor during the shift so you don't have to do that. And a slightly longer blip, when you're really getting on it, has been a normal part of the personality of the 998 SE5. Mine has done that ever since it came out of the crate. However, it has been reported on here that keeping your oil level towards the top of the band will tend to reduce that. Bottom line though, it's not a problem - it's a “feature”.
    Doug
    ”Freedom is not a loophole”
    Dec 2016
    Default Huge
    Quote Originally Posted by spyderfish View Post
    . Down to 2k and below..
    Dec 2016
    Default Full Throttle
    Quote Originally Posted by PW2013STL View Post
    No change in throttle.. Just upshifting..
    Apr 2017
    North Central Florida
    Quote Originally Posted by Snowbelt Spyder View Post
    You don't "blip" the throttle while shifting UP.
    And......if you really are keeping the throttle steady AND it was "pulling" when you shifted, a drop of 4K RPM or more certainly isn't normal.
    Now.....if you shifted in a "neutral throttle" condition or had reduced the throttle slightly without realizing it, then something like that might be normal.
    Dec 2016
    Default Solved..Wooohoooo
    Yes it was low oil, but now why?? No leak, less than 10k on the engine and oil change maybe 3k ago?? Should she be burning oil ?
    Mar 2013
    Quote Originally Posted by rkba101 View Post
    The twins are noted for using oil - so yes yours is normal.
    Apr 2017
    It might be normal; might not.
    Can't really say that unless he tells us how many miles since he last checked it AND how low it was.
    My guess is that he didn't check it at all in that 3000 miles and it could have been a bit low to start with.
    Nov 2015
    Chardon, OH
    That's right. As a person who has owned one for 6 years - they will use more oil than the 1330. It's just their design. Now that you know where the oil level is, a couple things to do. Be sure to check it in accordance with the procedure in the owner's manual - that is, oil level is checked with the oil hot - not just coolant hot. So the best time to do that is coming back from a long ride. And check it every 300 miles - also per the manual - until you get a feel for how your particular engine operates. Expect to use a quart between oil changes under normal operating conditions. Unlike your car, the "Add" mark on the dipstick is much less than a quart. And don't panic if you accidentally overfill it a little - key word being "little". And don't go only by miles. For example, riding the Blue Ridge Parkway - running around all day in second gear at higher RPMs - will use more oil based on miles than highway cruising. Check it more often under conditions like that or if you frequently run it hard. Not sure how new you are to the machine, but it's understandable that you are sensitive to all these little operating quirks. Rest easy - nothing you have reported here indicates anything out of the ordinary with your Spyder. Read the manual, do the maintenance and enjoy your ride.
    Doug
    Dec 2016
    Default Learning is the task at hand.
    Learn Learn Learning.. ! ! Thanks Guys !!
