Lamonster keyless fuel cap
I thought these looked pretty cool and my fuel cap is tough to get closed. I tried to do the install tonight and didn't get very far. The "beauty" screws didn't fit into the cap. It's almost like the cap was machined for smaller screws. I tried being careful to make sure no cross-threading was happening. I can only get the screws in about half way before they just lock up. Maybe it's the wrong threading in the cap? Anyone have experience with this?
2016 F3-T
Places I've ridden.
Call them
Call Lamonster. You may have to leave a message, but someone will get back to you quite quickly. They stand by their products and I'm confident will help you. FYI we got the cap for Jacque's F3S. Lamont installed it and the installation was rather straight forward and she loves it. Good luck.
Rob
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
Reacher, I have installed one of these on my 16 F3-T with no issues (apart from unscrewing that bloody bolt). I have a vague recollection (memory isn’t what it was), that there are two different lengths of screws.....only 3 screws fasten the cap to the body, and the other three are effectively decoration. Make sure you are using the right length screws in the right holes.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I got it figured out. I tried a little soap on the threads and then used Vaseline. I worked the screws in and out of the cap until I dug the threads deep enough to get the screws flush. I still couldn't seat them all the way, but you wouldn't know it by looking at it. I am wondering if they used the wrong tap on my fuel cap. The threads just didn't fit right. Getting the beauty screws in was, by far, the hardest part. I was able to get to the nut and fish the wire through without too much problem at all. The mounting screws fit perfectly and I am very happy with the result!
2016 F3-T
Places I've ridden.
How odd. I had no issues like that. It might be worth letting Lamont know, just in case there is a manufacturing glitch. Great to hear you got it sorted.
HeliBars Handlebars
Kenda Kanine rear.
What the heck is the beauty screw and what bloody bolt????
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Ahh well....
They are screws that do not have a function other than looking good...many of these style fuel covers , cars and trucks as well, have only a few screws that hold the cover onto the vehicle the rest just look good...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
SpyderLovers Founder
I got your message and called you but it went to voicemail. We chase all the threads before they leave here but I guess it's possible that one didn't get chased. There is no chance it's the wrong size tapped holes. The anodizing can cause a buildup and that's why we chase the threads. It's a M5 by 0.8 tap. Sorry about that.
Just watched the video posted at Lamonster Garage. I can truly say that bloody bolt and bloody wire fishing is just bloody hard.
Thanks for the call this morning. I'm glad we talked. I think what you said is correct and that you just didn't chase the threads on mine. I think it's ironic that the easy part took me a couple of hours and the hard part took about 10 minutes. Getting the tool on the square nut and fishing the wire through was much faster and easier than I expected.
Again, thanks for the quick response. I'm going to install the "Bright Ryder" tonight if I can figure out how to get the pins out of the trunk without damaging anything.
2016 F3-T
Places I've ridden.
If you use a small, flat screwdriver, you can lever the pins right out without touching any bodywork, Reacher. You can then get your fingernail under the base and just lift it right out. Lamont doesn’t bother putting the pins back in, and neither do I. The frunk insert stays perfectly in place without them.
HeliBars Handlebars
Kenda Kanine rear.
