Results 1 to 12 of 12
Thread: Rt
    Jun 2018
    Lakeland
    Default Rt
    I’ve only had my Can Am Spyders RT for two months purchased it from Sky Powersports in Lakeland Florida on June 21 it has been back to the shop three times when I first got it I told I call them that it was leaking all they came and got it said they repaired it I took it back to the shop on July 21 and the radiator reservoir was busted I don’t know how that got that way but it was in the shop for three weeks waiting on a part I got it back today rode it home Andpark it in the garage and a big oil puddle was up under my bike. This is my first bike I have a own and I am so Disappointed �� think I got a lemon.
    Mar 2015
    Brockport, NY
    Default Needs to go back to dealer
    That stinks that your initial experience has been sub par. I recommend taking back to dealer and when you get there ask them nicely if maybe “we” should involve brp at this time? Then follow up with an email to brp cares.
    2014 RT-S Pearl White
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default New or used?
    Was your Spyder new or used when purchased?
    Is it still under warranty? If so take it back to the dealer ASAP.
    You have been on this forum only for a short time - but if you follow the dialogue it is easy to tell that all dealers are not created equal with regards to their service departments. You are better to drive a few extra miles to get the Spyder to a shop with a good service track record.
    Good luck - sorry for your troubles.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Jun 2010
    Las Vegas
    So sorry to hear that you’re having a bad experience with your Spyder. As others have suggested it may actually be a problem with the dealer. Are you close to Central Florida Powersports? They have a very good reputation for service and I would suggest you take it there.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Need a new dealer....
    I see from your profile you have a 2012 RTL model therefore you got it used. You do need to have a good service department when you have an older model spyder as much of the work will no longer be waranty unless you have extended or other waranty. The resivior tank was a problem but a good dealer should have them in stock. You can get them form other sources in a few days. They should have checked the whole spyder for leaks....
    ​2012 RS sm5
    Sorry to hear that you're having trouble, but anyway!
    Default POOR DEALER SERVICE
    Quote Originally Posted by SpyderAnn01 View Post
    ......... Spyders aren't perfect ( but I have bought three so far ) .....it really sounds more like a dealer service dept. issue a recommendation from Ann01 above is a good thing .... Mike
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default those hose clamps ?
    wondering if the knuckle head mechanic , did not check too see if this was bad hose clamps ...
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default What type of warranty
    Did you get from the dealer? Since you bought it used from them, you should ask for a different used bike before you start pouring hundreds of dollars down the drain. Seems to me they should've gone over that bike top to bottom before they tried to sell it.
    Ride safe!
    2022 Sea-T0-Sky
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by KatherineH View Post
    Sorry you are having trouble with the bike. You mention a broken radiator reservoir and then talk about oil leaking. Looking at the pix, its hard to say whether that is coolant or oil leaking on the floor. If it's oil, it's a different problem than what you brought it in for. Did you put your finger in the liquid to verify what it is? If it is oil, there is a removable panel that you can just pop off and shine a light in there and you may see where it is coming from. You should be familiar with how to check the oil level on this bike anyway, it's not something you should put off for months or years at a time or leave for the dealer to do. If you are unsure, you could ask a mechanically inclined family member or friend to help out? Good luck and dont give up.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Call Central Florida PowerSports
    I believe Kissimmee, Fl is only about an hour away. Call them as they have a good Spyder reputation.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Oct 2016
    Sebring, FL
    I live in Lakeland, I have heard the stories coming from that shop, and they are not good. I know a Spyder RT rider here in Lakeland that bought from a reputable Clearwater dealer and was willing to ride there for service instead of buying locally here. I've also heard good reports from the Kissimmee dealer as mentioned in a previous post.
