Results 1 to 6 of 6
    Jun 2016
    Central Texas
    Default Front end alignment on 2012 RT in Centeral Texas
    Today I noticed that I have a little more wear on the inside of my right front than the other tire. Is there a good shop to get the front end aligned in the Austin/San Antonio area????
    Been a member for years, this is my first or second post.. Thanks
    Jul 2014
    Mint Hill, NC
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2010
    Las Vegas
    If you can wait until October we will be at the Texas Hill Country Rally in Boerne. We would be happy to get you squared away.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2018
    Fountain Hills,AZ
    Good Luck with them I've contacted 3 of those dealers in 2 states near me and None of them have time or even contact you back to set up a time to do it!! One dealer said don't bother me we're to busy to even think of doing any alignments for a long time!! WTH!
    Jun 2016
    Central Texas
    I may wait till Spyderann gets here. I am going to Ruidoso to the Rally next month.. Most likely can wait till I get back...Thanks for all the answers...
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Default tire wear
    Quote Originally Posted by Willard View Post
    You first need to check the a arm bushings, upper and lower and the ball joints for looseness. Alignment normaly will be wear across both tire and not just part of the tire.
    2014 RT SE6
