Results 1 to 25 of 26
    Linden, CA
    Default Important Message for all Spyder Lovers
    Mar 2015
    forrest above Reno, Nv
    Always check the blinker fluid
    2014 RTS , Circuit Yellow
    Mar 2013
    Oz
    Here is Jeff's favourite working-on-spyder t-shirt...
    Faribault, MN
    Dave, I nkow that's right, but doesn't the discusframbus plate bilate the bidirectional syncop of the reverse fundus rolator?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    I’m hoping that everbody is replacing the air in your tires at least every 6 months. It just seems to ride better with fresh air in the tires.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Default Interesting....🤔
    Sure...!!
    You Video guys will want to watch this one as soon as possible.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    and i watched the whole thing . [stupid human tricks] and just like some
    other videos-they didnt show how to adjust it.
    [joyce & irvin toms]
    Dave
    Have you called Tech Support yet?
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Triple B View Post
    Like you, up here in B.C. we replace our summer air in the tires with winter air for storage.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Oct 2010
    Wisconsin Rapids
    I just ordered a belt stabilizer for my muffler belt. I hope it stops the vibration. Also make sure you periodically synchronize your tire valve stems. They must be in the same position on each wheel to prevent unwanted wheel hop.
    Quote Originally Posted by Machinegunner View Post
    Aug 2010
    Newberg, Or.
    Dave, the solution is simple. Your shivigater isn't connected the the knicker pin. It's also possible that the wobblenbacher is loose. I went to collage to learn about that stuff! There, problem solved! Now you can,
    Ride in comfort,
    John
    Aug 2013
    I just did everything mentioned in this thread to my Spyder and now it won’t start?
    Oct 2014
    Fort Mill, SC
    Did it start before you did all that stuff?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Nov 2015
    Myerstown, Pennsylvania
    Here's a classic!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Aug 2010
    Newberg, Or.
    Quote Originally Posted by SteveLaoyster View Post
    Here's a classic!
    Guess that about sys it all. I'll be be using this approach in adjusting my side mirrors.
    Ride in comfort,
    John
    Thank goodness for those Marzelvanes!!
    Jul 2018
    Columbia,Tennessee
    Just back away from it and hope it doesn't start moving on it's own.
    Jul 2018
    Columbia,Tennessee
    Quote Originally Posted by bcer960 View Post
    Ray
    replace the air with every oil and filter change. That way your always in good shape
    Aug 2013
    Quote Originally Posted by SNOOPY View Post
    Quote Originally Posted by Grandpot View Post
    Well crap
    Aug 2010
    New York
    Remove the kickstands
    Active Member mark4Jesus's Avatar
    Sale Creek, Tennessee
    I hope the gullible members of this forum have not fallen for this shade tree mechanic nonsense! The most important thing you can do for you Spyder is to, at least once a year, adjust the tri-axle synchronizer so that all three wheels rotate at the same speed.
    2013 RT Limited.
    BajaRon Sway Bar.
    Refined Cycle's BPE2 brake pedal extension.
    Pedal Box
    2013 RT Limited , Refined Cycle BPE2 White
    Oct 2010
    Wisconsin Rapids
    Not only should all three wheels go the same speed, they should also go the same direction.
