SpyderLovers Sponsor
Important Message for all Spyder Lovers
Here is Jeff's favourite working-on-spyder t-shirt...
Dave, I nkow that's right, but doesn't the discusframbus plate bilate the bidirectional syncop of the reverse fundus rolator?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
I’m hoping that everbody is replacing the air in your tires at least every 6 months. It just seems to ride better with fresh air in the tires.
Bruce
2014 RTS-SE6
Tri-Axis Handlebars
Sena BT Dongle
Sirius Radio
Dash bar
Show Chrome Trunk Rack
"You know that a politician is lying if his lips are moving"
Interesting....🤔
You Video guys will want to watch this one as soon as possible.
and i watched the whole thing . [stupid human tricks] and just like some
other videos-they didnt show how to adjust it.
[joyce & irvin toms]
Dave
Have you called Tech Support yet?
Like you, up here in B.C. we replace our summer air in the tires with winter air for storage.
Ray
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
I just ordered a belt stabilizer for my muffler belt. I hope it stops the vibration. Also make sure you periodically synchronize your tire valve stems. They must be in the same position on each wheel to prevent unwanted wheel hop.
Originally Posted by Motorcycledave
Dave, the solution is simple. Your shivigater isn't connected the the knicker pin. It's also possible that the wobblenbacher is loose. I went to collage to learn about that stuff! There, problem solved! Now you can,
Ride in comfort,
John
I just did everything mentioned in this thread to my Spyder and now it won’t start?
Did it start before you did all that stuff?
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Originally Posted by SteveLaoyster
Here's a classic!
Guess that about sys it all. I'll be be using this approach in adjusting my side mirrors.
Ride in comfort,
John
Just back away from it and hope it doesn't start moving on it's own.
Ray
replace the air with every oil and filter change. That way your always in good shape
Well crap
I hope the gullible members of this forum have not fallen for this shade tree mechanic nonsense! The most important thing you can do for you Spyder is to, at least once a year, adjust the tri-axle synchronizer so that all three wheels rotate at the same speed.
2013 RT Limited.
BajaRon Sway Bar.
Refined Cycle's BPE2 brake pedal extension.
Pedal Box
Not only should all three wheels go the same speed, they should also go the same direction.
